Solaris 9 9/04 Installation Guide
Upgrade
An upgrade merges the new version of the Solaris operating environment with the existing files on the system's disk. An upgrade saves as many modifications as possible that you have made to the previous version of the Solaris operating environment.
You can upgrade any system that is running the Solaris 2.6, Solaris 7, or Solaris 8 software. Type the following command to see the version of Solaris software that is running on your system:
$ uname -a
You can upgrade the Solaris operating environment by using the following installation methods.
Note –
Use the smosservice patch to upgrade diskless clients. For detailed instructions, refer to System Administration Guide: Basic Administration or to smosservice(1M).
Solaris Upgrade Methods
Table 2–2 SPARC: Solaris Upgrade Methods
Current Solaris Operating Environment
Solaris 2.6, Solaris 7, Solaris 8, Solaris 9
  • SolarisTM Web Start program
  • Solaris suninstall program
  • Custom JumpStartTM method
  • Solaris Live Upgrade
Table 2–3 x86: Solaris Upgrade Methods
Solaris 2.6
Installing from DVD media or a net installation image:
  • Solaris Web Start program
  • Custom JumpStart method
Installing from CD media:
Solaris 7
Installing from DVD or CD media or a net installation image:
Upgrade Limitations
Note –
For limitations on upgrading using Solaris Live Upgrade, see Solaris Live Upgrade Requirements.
When upgrading, pay attention to the following issues.
