This chapter provides you with information about decisions you need to make before you install or upgrade the Solaris operating environment. This chapter contains the following sections:
This book uses the term slice, but some Solaris documentation and programs might refer to a slice as a partition. To avoid confusion, this book distinguishes between fdisk partitions (which are supported only in Solaris x86 Platform Edition) and the divisions within the Solaris fdisk partition, which might be called slices or partitions.
The following task map is an overview of the steps necessary to install or upgrade the Solaris operating environment. Use this task map to identify all of the decisions that you need to make to complete the most efficient installation for your environment.
Table 2–1 Task Map: Installing or Upgrading the Solaris Software|
Task |
Description |
For Instructions |
Choose initial installation or upgrade. |
Decide if you want to perform an initial installation or an upgrade. | |
Choose an installation method. |
The Solaris operating environment provides several methods for installation or upgrade. Choose the installation method that is most appropriate for your environment. |
Chapter 3, Choosing a Solaris Installation Method (Overview) |
Review system requirements. Also, plan and allocate disk space and swap space. |
Determine if your system meets the minimum requirements to install or upgrade. Allocate disk space on your system for the components of the Solaris operating environment that you want to install. Determine the appropriate swap space layout for your system. | |
Choose an installation location. |
You can install the Solaris software from local media or from the network. Decide on an installation location that is most appropriate for your environment. | |
Gather information about your system. |
Use the checklist and complete the worksheet to collect all of the information that you need to install or upgrade. |
Chapter 6, Gathering Information Before Installation or Upgrade (Planning) |
(Optional) Preconfigure system information. |
You can preconfigure system information to avoid being prompted for the information during the installation or upgrade. |
Chapter 7, Preconfiguring System Configuration Information (Tasks) |
(Optional) Prepare to install the Solaris software from the network. |
If you chose to install the Solaris software from the network, create an install server, create a boot server (if necessary), and set up the systems to be installed from the network. |
To install over a local area network, see Chapter 15, Preparing to Install From the Network With CD Media (Tasks). To install over a wide area network, see Chapter 43, Preparing to Install With WAN Boot (Tasks). |
(Upgrade only) Perform the pre-upgrade tasks. |
Back up your system, determine if you can upgrade with disk space reallocation, and search for patches that a Solaris Update release might override. |
Chapter 8, Upgrading the Solaris Operating Environment (Planning) |
Install or upgrade. |
Use the Solaris installation method that you chose to install or upgrade the Solaris software. |
The chapter or chapters that provide detailed instructions for the installation method |
Troubleshooting installation problems |
Review the troubleshooting information when you encounter problems with your installation. |
You can choose to perform an initial installation or, if your system is already running the Solaris operating environment, you can upgrade your system.
An initial installation overwrites the system's disk with the new version of the Solaris operating environment. If your system is not running the Solaris operating environment, you must perform an initial installation.
If the system is already running the Solaris operating environment, you can choose to perform an initial installation. If you want to preserve any local modifications, before you install, you must back up the local modifications. After you complete the installation, you can restore the local modifications.
You can use any of the Solaris installation methods to perform an initial installation. For detailed information about the different Solaris installation methods, refer to Chapter 3, Choosing a Solaris Installation Method (Overview).
An upgrade merges the new version of the Solaris operating environment with the existing files on the system's disk. An upgrade saves as many modifications as possible that you have made to the previous version of the Solaris operating environment.
You can upgrade any system that is running the Solaris 2.6, Solaris 7, or Solaris 8 software. Type the following command to see the version of Solaris software that is running on your system:
$ uname -a |
You can upgrade the Solaris operating environment by using the following installation methods.
Use the smosservice patch to upgrade diskless clients. For detailed instructions, refer to System Administration Guide: Basic Administration or to smosservice(1M).
Table 2–3 x86: Solaris Upgrade Methods
For limitations on upgrading using Solaris Live Upgrade, see Solaris Live Upgrade Requirements.
When upgrading, pay attention to the following issues.
Upgrading to another software group. You cannot upgrade your system to a software group that is not installed on the system. For example, if you previously installed the End User Solaris Software Group on your system, you cannot use the upgrade option to upgrade to the Developer Solaris Software Group. However, during the upgrade you can add software to the system that is not part of the currently installed software group.
Upgrading to a Solaris Update release. If you are already running the Solaris 9 operating environment and have installed individual patches, upgrading to a Solaris 9 Update release causes the following:
Any patches that were supplied as part of the Solaris 9 Update release are reapplied to your system. You cannot back out these patches.
Any patches that were previously installed on your system and are not included in the Solaris 9 Update release are removed.
You can use the Patch Analyzer to determine which patches, if any, will be removed by upgrading to the Solaris 9 Update release. For detailed instructions about using the Patch Analyzer, refer to Upgrading to a Solaris Update Release.
The Solaris software is distributed on DVD or CD media so that you can install or upgrade systems that have access to a DVD-ROM or CD-ROM drive.
If you have systems that do not have local DVD-ROM or CD-ROM drives or if you are installing several systems and do not want to insert the discs into every local drive to install the Solaris software, you can set up the systems to install from remote DVD or CD images.
You can use all of the Solaris installation methods to install a system from the network. However, by installing systems from the network with the Solaris Flash installation feature or with a custom JumpStart installation, you can centralize and automate the installation process in a large enterprise. For more details about the different installation methods, refer to Chapter 3, Choosing a Solaris Installation Method (Overview).
Installing the Solaris software from the network requires initial setup. For information about preparing to install from the network, choose one of the following options.
For detailed instructions on preparing to install from a local area network, refer to Chapter 15, Preparing to Install From the Network With CD Media (Tasks).
For instructions on preparing to install over a wide area network, see Chapter 43, Preparing to Install With WAN Boot (Tasks).
For instructions about how to install x86–based clients over the network by using PXE, see x86: Booting and Installing Over the Network With PXE.
When you are using DVD media and are asked to boot from the ok prompt, always type the following command:
ok boot cdrom |
If you are using the SunTM ONE Application Server, you need to configure the server after installing the Solaris operating environment. For information on configuring the Application Server, see Sun ONE Application Server 7 Standard Edition Getting Started Guide.
The Solaris Device Configuration Assistant is a program that enables you to perform various hardware configuration and booting tasks. You use the Device Configuration Assistant to boot from either a DVD, a CD, a net installation image, or a copy of the software on a diskette. You can access the Solaris Device Configuration Assistant in the following ways:
By booting from the Solaris DVD, Solaris Installation CD, or Solaris Software 1 of 2 CD. Your system's BIOS must support booting from a DVD or CD.
By booting from a net installation image of Solaris Software with Preboot Execution Environment (PXE). PXE enables you to boot a system directly from the network without using the boot diskette. The system must support PXE. Enable the system to use PXE by using the system's BIOS setup tool or the network adapter's configuration setup Tool. For more information on configuring your system for using PXE network boot, see x86: Booting and Installing Over the Network With PXE.
By booting from a diskette. You can copy the Device Configuration Assistant software to a diskette from the Solaris x86 Platform Edition DVD or Solaris Software 2 of 2 x86 Platform Edition CD by using the copy procedure in Appendix I, x86: Preparing to Boot From the Solaris Device Configuration Assistant or the Network (Tasks).
