You can use the network_interface keyword to configure a single interface in the following ways.
With DHCP – You can use a DHCP server on your network to configure the network interface. For more information on how to use a DHCP server during your installation, see Preconfiguring System Configuration Information With the DHCP Service (Tasks).
To use the DHCP server to configure a single interface on the system, use the following syntax for the network_interface keyword.
network_interface=PRIMARY or value
{dhcp protocol_ipv6=yes-or-no}
Instructs the installation program to configure the first up, non-loopback interface that is found on the system. The order is the same as the order that is displayed with the ifconfig command. If no interfaces are up, then the first non-loopback interface is used. If no non-loopback interfaces are found, then the system is non-networked.
Instructs the installation program to configure a specific interface, such as hme0 or eri1.
Instructs the installation program to configure the system to either use IPv6 or to not use IPv6.
For WAN boot installations, you must set the value of protocol_ipv6=no.
Without DHCP – If you do not want to use DHCP to configure the network interface, you can specify the configuration information in the sysidcfg file. To instruct the installation program to configure a single interface on the system without using DHCP, use the following syntax.
{hostname=host_name
default_route=ip_address
ip_address=ip_address
netmask=netmask
protocol_ipv6=yes_or_no}
Instructs the installation program to configure the first up, non-loopback interface that is found on the system. The order is the same as the order that is displayed with the ifconfig command. If no interfaces are up, then the first non-loopback interface is used. If no non-loopback interfaces are found, then the system is not networked.
Do not use the PRIMARY keyword value if you want to configure multiple interfaces.
(Optional) Specifies the host name of the system.
(Optional) Specifies the IP address of the default router. If you want the installation program to detect the router by using the ICMP router discovery protocol, omit this keyword.
If the installation program cannot detect the router, you are prompted for the router information during the installation.
(Optional) Specifies the IP address of the system.
(Optional) Specifies the netmask value for the system.
(Optional) Instructs the installation program to configure the system to either use IPv6 or to not use IPv6.
To perform an unattended custom JumpStart installation, you must specify a value for the protocol_ipv6 keyword.
Include any combination or none of the hostname, ip_address, and netmask keywords, as needed. If you do not use any of these keywords, omit the curly braces ({}).
The following example instructs the installation program to use DHCP to configure the eri0 network interface. IPv6 support is not enabled.
network_interface=eri0 {dhcp protocol_ipv6=no}
The following example configures the interface eri0 with the following settings.
The host name is set to host1.
The IP address is set to 172.31.88.100.
The netmask is set to 255.255.255.0.
IPv6 support is not enabled on the interface.
network_interface=eri0 {hostname=host1 ip_address=172.31.88.100
netmask=255.255.255.0 protocol_ipv6=no}
