Solaris 9 9/04 Installation Guide
SPARC: Preconfiguring Power Management Information
You can use the Power Management software that is provided in the Solaris environment to automatically save the state of a system and turn it off after it is idle for 30 minutes. When you install the Solaris 9 software on a system that complies with version 2 of the EPA's Energy Star guidelines, for example a sun4u system, the Power Management software is installed by default. During a Solaris Web Start installation, the installation program prompts you to enable or disable the Power Management software. The suninstall installation program prompts you to enable or disable the Power Management software after the installation is complete and the system reboots.
Note –
If your system has Energy Star version 3 or later, you are not prompted for this information.
If you are performing interactive installations, you cannot preconfigure the Power Management information and avoid the prompt. However, by using a custom JumpStart installation, you can preconfigure the Power Management information by using a finish script to create an /autoshutdown or /noautoshutdown file on the system. When the system reboots, the /autoshutdown file enables Power Management and the /noautoshutdown file disables Power Management.
For example, the following line in a finish script enables the Power Management software and prevents the display of the prompt after the system reboots.
touch /a/autoshutdown
Finish scripts are described in Creating Finish Scripts.
