Solaris 9 9/04 Installation Guide
terminal Keyword
You can use the terminal keyword to specify the terminal type for the system. Use the following syntax to specify the terminal type.
terminal=terminal_type
terminal_type specifies the terminal type for the system. For a list of valid terminal values, see the subdirectories in the /usr/share/lib/terminfo directory.
