This book describes how to install and upgrade the SolarisTM 9 operating environment on both networked and non-networked SPARC® and x86 architecture based systems.
This book does not include instructions about how to set up system hardware or other peripherals.
The Solaris operating environment runs on two types of hardware, or platforms—SPARC and x86. The information in this document pertains to both platforms unless called out in a special chapter, section, note, bulleted item, figure, table, example, or code example.
In this document the term “x86” refers to the Intel 32-bit family of microprocessor chips and compatible microprocessor chips made by AMD.
This book is intended for system administrators responsible for installing the Solaris operating environment. This book provides both of the following types of information.
Advanced Solaris installation information for enterprise system administrators who manage multiple Solaris machines in a networked environment
Basic Solaris installation information for system administrators who perform infrequent Solaris installations or upgrades
Table P–1 lists related information that you need when you install the Solaris software.
Table P–1 Related Information|
Information |
Description |
Describes how to back up system files |
Solaris 9 9/04 Release Notes |
Describes any bugs, known problems, software that is being discontinued, and patches that are related to the Solaris release |
SPARC: Solaris 9 Sun Hardware Platform Guide |
Contains information about supported hardware |
Solaris 9 9/04 Package List |
Lists and describes the packages in the Solaris 9 9/04 operating environment |
x86: Solaris (x86 Platform Edition) Hardware Compatibility List |
Contains supported hardware information and device configuration |
The docs.sun.comSM Web site enables you to access Sun technical documentation online. You can browse the docs.sun.com archive or search for a specific book title or subject. The URL is http://docs.sun.com.
Sun Microsystems offers select product documentation in print. For a list of documents and how to order them, see “Buy printed documentation” at http://docs.sun.com.
The following table describes the typographic changes that are used in this book.
Table P–2 Typographic Conventions|
Typeface or Symbol |
Meaning |
Example |
AaBbCc123 | The names of commands, files, and directories, and onscreen computer output |
Edit your .login file. Use ls -a to list all files. machine_name% you have mail. |
AaBbCc123 | What you type, contrasted with onscreen computer output |
machine_name% su Password: |
AaBbCc123 | Command-line placeholder: replace with a real name or value |
The command to remove a file is rm filename. |
AaBbCc123 |
Book titles, new terms or terms to be emphasized |
Read Chapter 6 in the User's Guide. These are called class options. Do not save the file. |
The following table shows the default system prompt and superuser prompt for the C shell, Bourne shell, and Korn shell.
Table P–3 Shell Prompts|
Shell |
Prompt |
| C shell prompt | machine_name% |
| C shell superuser prompt | machine_name# |
| Bourne shell and Korn shell prompt | $ |
| Bourne shell and Korn shell superuser prompt | # |
