Solaris 9 9/04 Installation Guide
To Display the Status of All Boot Environments (Character Interface)
  1. From the main menu, select Status.
    A table that is similar to the following is displayed:
    boot environment   Is        Active  Active     Can	    Copy
    Name               Complete  Now	 OnReboot   Delete	 Status
    disk_a_S7          yes       yes     yes        no       -
    disk_b_S7database  yes       no      no         yes      COPYING
    disk_b_S8          no        no      no         yes      -
    Note –
    In this example, you could not perform copy, rename, or upgrade operations on disk_b_S8 because it is not complete, nor on disk_b_S7database, because a live upgrade operation is in progress.
