The wanboot-cgi program creates the data streams that transmit the the following files from the WAN boot server to the client.
wanboot program
WAN boot file system
WAN boot miniroot
The wanboot-cgi program is installed on the system when you install the Solaris 9 12/03 operating environment, or compatible version. To enable the WAN boot server to use this program, copy this program to the cgi-bin directory of the WAN boot server.
Become superuser on the WAN boot server.
Copy the wanboot-cgi program to the WAN boot server.
# cp /usr/lib/inet/wanboot/wanboot-cgi /WAN-server-root/cgi-bin/wanboot-cgi |
Specifies the root directory of the web server software on the WAN boot server
On the WAN boot server, change the permissions of the CGI program to 755.
# chmod 755 /WAN-server-root/cgi-bin/wanboot-cgi |
