You can specify a set of keywords in the sysidcfg file to preconfigure a system. For more detailed information about sysidcfg keywords and values, see Preconfiguring With the sysidcfg File.
Create a file called sysidcfg in a text editor on the install server.
Type the sysidcfg keywords you want.
For detailed information about sysidcfg keywords, see sysidcfg File Keywords.
Save the sysidcfg file in a location that is accessible to the WAN boot server.
Save the file to one of the following locations.
If the WAN boot server and install server are hosted on the same machine, save this file to the flash subdirectory of the document root directory on the WAN boot server.
If the WAN boot server and install server are not on the same machine, save this file to the flash subdirectory of the document root directory of the install server.
The following is an example of a sysidcfg file for a SPARC based system. The host name, IP address, and netmask of this system have been preconfigured by editing the name service.
network_interface=primary {hostname=seahag
default_route=192.168.88.1
ip_address=192.168.88.210
netmask=255.255.0.0
protocol_ipv6=no}
timezone=US/Central
system_locale=C
terminal=xterm
timeserver=localhost
name_service=NIS {name_server=matter(192.168.255.255)
domain_name=mind.over.example.com
security_policy=none
