Solaris 9 9/04 Installation Guide
Using Digital Certificates for Server and Client Authentication
The WAN boot installation method can use PKCS#12 files to perform an installation over HTTPS with server or both client and server authentication. For requirements and guidelines about using PKCS#12 files, see Digital Certificate Requirements.
To use a PKCS#12 file in a WAN boot installation, you perform the following tasks.
The wanbootutil command provides options to perform the tasks in the previous list.
Before you split a PKCS#12 file, create the appropriate subdirectories of the /etc/netboot hierarchy on the WAN boot server.
Creating a Trusted Certificate and Client Private Key
  1. Assume the same user role as the web server user on the WAN boot server.
  2. Extract the trusted certificate from the PKCS#12 file. Insert the certificate in the client's truststore file in the /etc/netboot hierarchy.
    # wanbootutil p12split -i p12cert \
      -t /etc/netboot/net-ip/client-ID/truststore
    p12split
    Option to wanbootutil command that splits a PKCS#12 file into separate private key and certificate files.
    -i p12cert
    Specifies the name of the PKCS#12 file to split.
    Inserts the certificate in the client's truststore file. net-ip is the IP address of the client's subnet. client-ID can be a user-defined ID or the DHCP client ID.
  3. (Optional) Decide if you want to require client authentication.
    1. Insert the client certificate in the client's certstore.
      # wanbootutil p12split -i p12cert -c \
        /etc/netboot/net-ip/client-ID/certstore -k keyfile
      p12split
      -i p12cert
      -c /etc/netboot/net-ip/client-ID/certstore
      Inserts the client's certificate in the client's certstore. net-ip is the IP address of the client's subnet. client-ID can be a user-defined ID or the DHCP client ID.
      -k keyfile
      Specifies the name of the client's SSL private key file to create from the split PKCS#12 file.
    2. Insert the private key in the client's keystore.
      # wanbootutil keymgmt -i -k keyfile \
         -s /etc/netboot/net-ip/client-ID/keystore -o type=rsa
      keymgmt -i
      Inserts an SSL private key in the client's keystore
      -k keyfile
      Specifies the name of the client's private key file that was created in the previous step
      Specifies the path to the client's keystore
      -o type=rsa
      Specifies the key type as RSA
Example 43–3 Creating a Trusted Certificate for Server Authentication
In the following example, you use a PKCS#12 file to install client 010003BA152A42 on subnet 192.168.255.0. This command sample extracts a certificate from a PKCS#12 file that is named client.p12. The command then places the contents of the trusted certificate in the client's truststore file.
Before you execute these commands, you must first assume the same user role as the web server user. In this example, the web server user role is nobody.
server# su nobody
Password:
nobody# wanbootutil p12split -i client.p12 \
   -t /etc/netboot/192.168.255.0/010003BA152A42/truststore
nobody# chmod 600 /etc/netboot/192.168.255.0/010003BA152A42/truststore
