WAN boot performs a custom JumpStart installation to install a Solaris Flash archive on the client. The custom JumpStart installation method is a command–line interface that enables you to automatically install several systems, based on profiles that you create. The profiles define specific software installation requirements. You can also incorporate shell scripts to include preinstallation and postinstallation tasks. You choose which profile and scripts to use for installation or upgrade. The custom JumpStart installation method installs or upgrades the system, based on the profile and scripts that you select. Also, you can use a sysidcfg file to specify configuration information so that the custom JumpStart installation is completely free of manual intervention.
To prepare the custom JumpStart files for a WAN boot installation, complete the following tasks.
For detailed information on the custom JumpStart installation method, see Chapter 25, Custom JumpStart (Overview).
The Solaris Flash installation feature enables you to use a single reference installation of the Solaris operating environment on a system, which is called the master system. You can then create a Solaris Flash archive, which is a replica image of the master system. You can install the Solaris Flash archive on other systems in the network, creating clone systems.
This section describes how to create a Solaris Flash archive to use in your WAN boot installation. Before you create a Solaris Flash archive, you must first install the master system.
For information about installing a master system, see Installing the Master System.
For detailed information about Solaris Flash archives, see Chapter 21, Creating Solaris Flash Archives (Tasks).
For detailed instructions about how to create a Solaris Flash archive, see Creating a Solaris Flash Archive.
Boot the master system.
Run the master system in as inactive a state as possible. When possible, run the system in single-user mode. If that is not possible, shut down any applications that you want to archive and any applications that require extensive operating system resources.
To create the archive, use the flar create command.
# flar create -n name [optional-parameters] document-root/flash/filename |
The name that you give the archive. The name you specify is the value of the content_name keyword.
You can use several options to the flar create command to customize your Solaris Flash archive. For detailed descriptions of these options, see Chapter 23, Solaris Flash (Reference).
The path to the Solaris Flash subdirectory of the install server's document root directory.
The name of the archive file.
To conserve disk space, you might want to use the -c option to the flar create command to compress the archive. However, a compressed archive can affect the performance of your WAN boot installation. For more information about creating a compressed archive, see the man page flar create(1M).
If the archive creation is successful, the flar create command returns an exit code of 0.
If the archive creation fails, the flar create command returns a nonzero exit code.
For examples of how to create a Solaris Flash archive, see Examples—Creating an Archive for an Initial Install.
You can specify a set of keywords in the sysidcfg file to preconfigure a system. For more detailed information about sysidcfg keywords and values, see Preconfiguring With the sysidcfg File.
Create a file called sysidcfg in a text editor on the install server.
Type the sysidcfg keywords you want.
For detailed information about sysidcfg keywords, see sysidcfg File Keywords.
Save the sysidcfg file in a location that is accessible to the WAN boot server.
Save the file to one of the following locations.
If the WAN boot server and install server are hosted on the same machine, save this file to the flash subdirectory of the document root directory on the WAN boot server.
If the WAN boot server and install server are not on the same machine, save this file to the flash subdirectory of the document root directory of the install server.
The following is an example of a sysidcfg file for a SPARC based system. The host name, IP address, and netmask of this system have been preconfigured by editing the name service.
network_interface=primary {hostname=seahag
default_route=192.168.88.1
ip_address=192.168.88.210
netmask=255.255.0.0
protocol_ipv6=no}
timezone=US/Central
system_locale=C
terminal=xterm
timeserver=localhost
name_service=NIS {name_server=matter(192.168.255.255)
domain_name=mind.over.example.com
security_policy=none
A profile is a text file that instructs the custom JumpStart program how to install the Solaris software on a system. A profile defines elements of the installation, for example, the software group to install.
For detailed information about how to create profiles, see Creating a Profile.
Create a text file on the install server. Name the file descriptively.
Ensure that the name of the profile reflects how you intend to use the profile to install the Solaris software on a system. For example, you might name the profiles basic_install, eng_profile, or user_profile.
Add profile keywords and values to the profile.
For a list of profile keywords and values, see Profile Keywords and Values.
Profile keywords and their values are case sensitive.
Save the profile in a location that is accessible to the WAN boot server.
Save the profile in one of the following locations.
Ensure that root owns the profile and that the permissions are set to 644.
(Optional) Test the profile.
Testing a Profile contains information about testing profiles.
In the following example, the profile indicates that the custom JumpStart program retrieves the Solaris Flash archive from a secure HTTP server.
# profile keywords profile values # ---------------- ------------------- install_type flash_install archive_location https://192.168.255.255/solarisupdate.flar partitioning explicit filesys c0t1d0s0 4000 / filesys c0t1d0s1 512 swap filesys c0t1d0s7 free /export/home
The following list describes some of the keywords and values from this example.
The profile installs a Solaris Flash archive on the clone system. All files are overwritten as in an initial installation.
The compressed Solaris Flash archive is retrieved from a secure HTTP server.
The file system slices are determined by the filesys keywords, value explicit. The size of root (/) is based on the size of the Solaris Flash archive. The size of swap is set to the necessary size and is installed on c0t1d0s1. /export/home is based on the remaining disk space. /export/home is installed on c0t1d0s7.
The rules file is a text file that contains a rule for each group of systems on which you want to install the Solaris operating environment. Each rule distinguishes a group of systems that are based on one or more system attributes. Each rule also links each group to a profile. A profile is a text file that defines how the Solaris software is to be installed on each system in the group. For example, the following rule specifies that the JumpStart program use the information in the basic_prof profile to install any system with the sun4u platform group.
karch sun4u - basic_prof - |
The rules file is used to create the rules.ok file, which is required for custom JumpStart installations.
For detailed information about how to create a rules file, see Creating the rules File.
On the install server, create a text file that is named rules.
Add a rule in the rules file for each group of systems you want to install.
Save the rules file on the install server.
$ ./check [[-p path -r file-name]] |
Validates the rules by using the check script from the Solaris 9 software image instead of the check script from the system you are using. path is the image on a local disk or a mounted Solaris DVD or a Solaris Software 1 of 2 CD.
Use this option to run the most recent version of check if your system is running a previous version of Solaris.
Specifies a rules file other than the file that is named rules. By using this option, you can test the validity of a rule before you integrate the rule into the rules file.
As the check script runs, the script reports the checking of the validity of the rules file and each profile. If no errors are encountered, the script reports: The custom JumpStart configuration is ok. The check script creates the rules.ok file.
Save the rules.ok file in a location that is accessible to the WAN boot server.
Ensure that root owns the rules.ok file and that the permissions are set to 644.
For examples of rules files, see rules File Example.
Begin and finish scripts are user-defined Bourne shell scripts that you specify in the rules file. A begin script performs tasks before the Solaris software is installed on a system. A finish script performs tasks after the Solaris software is installed on a system, but before the system reboots. You can use these scripts only when using custom JumpStart to install Solaris.
You can use begin scripts to create derived profiles. Finish scripts enable you to perform various postinstallation tasks, such as adding files, packages, patches, or additional software.
You must store the begin and finish scripts in the same directory as the sysidcfg, rules.ok, and profile files on the install server.
For more information about creating begin scripts, see Creating Begin Scripts.
For more information about creating finish scripts, see Creating Finish Scripts.
