You can either install or upgrade the Solaris operating environment by using the Solaris Web Start program, which is on the Solaris SPARC Platform Edition DVD or the Solaris SPARC Platform Edition Installation CD.
If you are installing from the Solaris Installation CD, refer to Requirements When Using the Solaris Installation CD for special requirements.
For the installation, ensure that you have the following:
For a DVD installation, the Solaris SPARC Platform Edition DVD
For a CD installation:
Solaris Software 1 of 2 SPARC Platform Edition CD.
Solaris Software 2 of 2 SPARC Platform Edition CD – The installation program prompts you for this CD if necessary.
Solaris SPARC Platform Edition Languages CD – The installation program prompts you for this CD if necessary to support languages for specific geographic regions.
Task |
Description |
For Instructions |
Verify system requirements. |
Verify that your system meets the requirements to install or upgrade with the Solaris Web Start program. | |
Gather the necessary information. |
Follow the checklist and complete the worksheet to be sure that you have all of the information you need to install the Solaris software. |
Chapter 6, Gathering Information Before Installation or Upgrade (Planning) |
(Optional) Preconfigure system configuration information. |
Use the sysidcfg file or the name service to preconfigure installation information (for example, locale) for a system. Preconfiguring system information prevents the installation program from prompting you during the installation. |
Chapter 7, Preconfiguring System Configuration Information (Tasks) |
(Upgrade only) Prepare to upgrade the system. |
Back up the system. | |
(Optional) Set up the system to install from the network. |
To install a system from a remote DVD or CD net installation image, you need to set up the system to boot and install from an install server or boot server. |
Chapter 15, Preparing to Install From the Network With CD Media (Tasks) |
Install or upgrade. |
Boot the system and follow the prompts to install or upgrade the Solaris software. |
SPARC: To Perform an Installation or Upgrade With the Solaris Web Start Program |
(Upgrade only) Perform post-upgrade tasks. |
Correct any local modifications that were lost during the upgrade. |
Decide if you want to install the software by using the DVD-ROM or CD-ROM drive or by using a net image.
If you're using a DVD-ROM or CD-ROM drive, insert the Solaris SPARC Platform Edition DVD or Solaris SPARC Platform Edition Installation CD.
If you're using a net installation image, change directories to where the installation media is located. You might need to contact your network administrator for the location. For more information on installing from the network, see Chapter 14, Preparing to Install From the Network With DVD Media (Tasks) or Chapter 15, Preparing to Install From the Network With CD Media (Tasks).
Boot the system.
If the system is new, out-of-the-box, turn on the system.
If you want to install or upgrade an existing system, shut down the system.
To boot from the local DVD or CD, type the following command.
ok boot cdrom [[- nowin]] |
To boot from an install server on a network, type the following command.
ok boot net [[- nowin]] |
Specifies to run the Solaris Web Start program in CLI mode.
The Solaris Web Start installation begins.
If you are prompted, answer the system configuration questions.
If you preconfigured all of the system configuration information, the Solaris Web Start program does not prompt you to enter any configuration information.
If you did not preconfigure the system configuration information, use the Worksheet for Installation or the Worksheet for Upgrading to help you answer the system configuration questions.
If you are using the GUI, after you confirm the system configuration information, the Solaris Web Start Installation Kiosk and Welcome to Solaris dialog box appear. If your system has insufficient memory, the Kiosk does not display.
You can click on any link in the Kiosk menu.
In some situations, the Kiosk might cover a dialog box. To display a hidden dialog box, from the Kiosk menu, choose Send Kiosk to Background.
The Installer Questions screen appears.
Decide if you want to reboot the system automatically and if you want to automatically eject the disc. Click NEXT.
The Specify Media screen appears.
Specify the media you are using to install.
If you are installing a Solaris Flash archive, continue.
If you are not installing a Solaris Flash archive, proceed to Step 6.
Type the information that you are prompted to enter.
Media Selected |
Prompt |
DVD or CD |
Insert the disc where the Solaris Flash archive is located. |
Network File System |
Specify the path to the network file system where the Solaris Flash archive is located. You can also specify the archive file name. |
HTTP |
Specify the URL and proxy information that is needed to access the Solaris Flash archive. |
FTP |
Specify the FTP server and the path to the Solaris Flash archive. Specify the user and password information that allows you access to the FTP server. Specify any proxy information that is needed to access the FTP server. |
Local tape |
Specify the local tape device and the position on the tape where the Solaris Flash archive is located. |
If you selected to install an archive from a DVD, CD, or from an NFS server, the Select Flash Archives panel is displayed.
For archives that are stored on a disc or an NFS server, on the Select Flash Archives panel, select one or more Solaris Flash archives to install.
On the Flash Archives Summary panel, confirm the selected archives and click Next.
On the Additional Flash Archives panel, you can install an additional Solaris Flash archive by specifying the media where the other archive is located. If you do not want to install additional archives, select None and click Next to continue the installation. Proceed to Step 7.
Decide if you want to perform an initial installation or an upgrade.
The Solaris Web Start program determines if the system can be upgraded. You must have an existing Solaris root (/) file system. If you are upgrading by using the Solaris Installation CD, you must have a 512–Mbyte slice. The Solaris Web Start program detects the necessary conditions and then upgrades the system.
Follow the instructions on the screen to install the Solaris software. If you are NOT installing a Solaris Flash archive, you can also install additional software.
When the Solaris Web Start program finishes installing the Solaris software, the system reboots automatically or prompts you to reboot manually.
After the installation is finished, installation logs are saved in a file. You can find the installation logs in the following directories:
/var/sadm/system/logs
/var/sadm/install/logs
If you are upgrading the Solaris software, you might need to correct some local modifications that were not preserved. For detailed instructions, refer to To Correct Local Modifications After Upgrading.
