Use one of the following methods to check mirror or submirror status.
From the Enhanced Storage tool within the Solaris Management Console, open the Volumes node, choose the mirror, then choose Action->Properties. Follow the instructions on screen. For more information, see the online help.
Run the metastat command on a mirror to see the state of each submirror, the pass number, the read option, the write option, and the size of the total number of blocks in mirror. For example, to check the status of the one-way mirror d70, use:
# metastat d70
d70: Mirror
    Submirror 0: d71
      State: Okay
    Pass: 1
    Read option: roundrobin (default)
    Write option: parallel (default)
d71: Submirror of d70
    State: Okay
    Stripe 0:
        Device              Start Block  Dbase State        Reloc  Hot Spare
        c1t3d0s3                   0     No    Okay         Yes
    Stripe 1:
        c1t3d0s4                   0     No    Okay         Yes
    Stripe 2:
        c1t3d0s5                   0     No    Okay         Yes
See How to Change RAID 1 Volume Options to change a mirror's pass number, read option, or write option.
See metastat(1M) for more information about checking device status.
Here is sample output from the metastat command.
# metastat
d0: Mirror
    Submirror 0: d1
      State: Okay
    Submirror 1: d2
      State: Okay
    Pass: 1
d1: Submirror of d0
    State: Okay
    Stripe 0:
        Device              Start Block  Dbase State        Hot Spare
        c0t2d0s7                   0     No    Okay
For each submirror in the mirror, the metastat command shows the state, an “invoke” line if there is an error, the assigned hot spare pool (if any), size in blocks, and information about each slice in the submirror.
