Task |
Description |
For Instructions |
Manage storage in which one or more components is greater than 1 TB |
Use physical LUNs that are greater than 1 TB in size, or create logical volumes that are greater than 1 TB. | |
Import a disk set from one system to another |
Use the metaimport command to import disk sets, even disk sets created on different systems. This command uses expanded device ID support to automatically track disk movement within named disk sets. |
