This chapter provides information about performing general storage administration maintenance tasks with Solaris Volume Manager.
This is a list of the information in this chapter:
The following task map identifies the procedures needed to maintain Solaris Volume Manager.
Task |
Description |
Instructions |
View the Solaris Volume Manager configuration |
Use the Solaris Volume Manager GUI or the metastat command to view the system configuration. | |
Rename a volume |
Use the Solaris Volume Manager GUI or the metarename command to rename a volume. | |
Create configuration files |
Use the metastat -p command and the metadb command to create configuration files. | |
Initialize Solaris Volume Manager from configuration files |
Use the metainit command to initialize Solaris Volume Manager from configuration files. |
How to Initialize Solaris Volume Manager From a Configuration File |
Increase the number of possible volumes |
Edit the /kernel/drv/md.conf file to increase the number of possible volumes. | |
Increase the number of possible disk sets |
Edit the /kernel/drv/md.conf file to increase the number of possible disk sets. | |
Grow a file system |
Use the growfs command to grow a file system. | |
Enable components |
Use the Solaris Volume Manager GUI or the metareplace command to enable components. | |
Replace components |
Use the Solaris Volume Manager GUI or the metareplace command to replace components. |
The metastat command does not sort output. Pipe the output of the metastat -p command to the sort or grep commands for a more manageable listing of your configuration.
To view the volume configuration, use one of the following methods:
From the Enhanced Storage tool within the Solaris Management Console, open the Volumes node. For more information, see the online help.
Use the following format of the metastat command:
metastat -p -i component-name |
-p specifies to output a condensed summary, suitable for use in creating the md.tab file.
-i specifies to verify that all devices can be accessed.
component-name is the name of the volume to view. If no volume name is specified, a complete list of components will be displayed.
The following example illustrates output from the metastat command.
# metastat d50: RAID State: Okay Interlace: 32 blocks Size: 20985804 blocks Original device: Size: 20987680 blocks Device Start Block Dbase State Reloc Hot Spare c1t4d0s5 330 No Okay Yes c1t5d0s5 330 No Okay Yes c2t4d0s5 330 No Okay Yes c2t5d0s5 330 No Okay Yes c1t1d0s5 330 No Okay Yes c2t1d0s5 330 No Okay Yes d1: Concat/Stripe Size: 4197879 blocks Stripe 0: Device Start Block Dbase Reloc c1t2d0s3 0 No Yes d2: Concat/Stripe Size: 4197879 blocks Stripe 0: Device Start Block Dbase Reloc c2t2d0s3 0 No Yes d80: Soft Partition Device: d70 State: Okay Size: 2097152 blocks Extent Start Block Block count 0 1 2097152 d81: Soft Partition Device: d70 State: Okay Size: 2097152 blocks Extent Start Block Block count 0 2097154 2097152 d70: Mirror Submirror 0: d71 State: Okay Submirror 1: d72 State: Okay Pass: 1 Read option: roundrobin (default) Write option: parallel (default) Size: 12593637 blocks d71: Submirror of d70 State: Okay Size: 12593637 blocks Stripe 0: Device Start Block Dbase State Reloc Hot Spare c1t3d0s3 0 No Okay Yes Stripe 1: Device Start Block Dbase State Reloc Hot Spare c1t3d0s4 0 No Okay Yes Stripe 2: Device Start Block Dbase State Reloc Hot Spare c1t3d0s5 0 No Okay Yes d72: Submirror of d70 State: Okay Size: 12593637 blocks Stripe 0: Device Start Block Dbase State Reloc Hot Spare c2t3d0s3 0 No Okay Yes Stripe 1: Device Start Block Dbase State Reloc Hot Spare c2t3d0s4 0 No Okay Yes Stripe 2: Device Start Block Dbase State Reloc Hot Spare c2t3d0s5 0 No Okay Yes hsp010: is empty hsp014: 2 hot spares Device Status Length Reloc c1t2d0s1 Available 617652 blocks Yes c2t2d0s1 Available 617652 blocks Yes hsp050: 2 hot spares Device Status Length Reloc c1t2d0s5 Available 4197879 blocks Yes c2t2d0s5 Available 4197879 blocks Yes hsp070: 2 hot spares Device Status Length Reloc c1t2d0s4 Available 4197879 blocks Yes c2t2d0s4 Available 4197879 blocks Yes Device Relocation Information: Device Reloc Device ID c1t2d0 Yes id1,sd@SSEAGATE_ST39204LCSUN9.0G3BV0N1S200002103AF29 c2t2d0 Yes id1,sd@SSEAGATE_ST39204LCSUN9.0G3BV0P64Z00002105Q6J7 c1t1d0 Yes id1,sd@SSEAGATE_ST39204LCSUN9.0G3BV0N1EM00002104NP2J c2t1d0 Yes id1,sd@SSEAGATE_ST39204LCSUN9.0G3BV0N93J000071040L3S c0t0d0 Yes id1,dad@s53554e575f4154415f5f53543339313430412525415933 |
The following example illustrates output from the metastat command for a large storage volume (11 TB).
# metastat d0 d0: Concat/Stripe Size: 25074708480 blocks (11 TB) Stripe 0: (interlace: 32 blocks) Device Start Block Dbase Reloc c27t8d3s0 0 No Yes c4t7d0s0 12288 No Yes Stripe 1: (interlace: 32 blocks) Device Start Block Dbase Reloc c13t2d1s0 16384 No Yes c13t4d1s0 16384 No Yes c13t6d1s0 16384 No Yes c13t8d1s0 16384 No Yes c16t3d0s0 16384 No Yes c16t5d0s0 16384 No Yes c16t7d0s0 16384 No Yes c20t4d1s0 16384 No Yes c20t6d1s0 16384 No Yes c20t8d1s0 16384 No Yes c9t1d0s0 16384 No Yes c9t3d0s0 16384 No Yes c9t5d0s0 16384 No Yes c9t7d0s0 16384 No Yes Stripe 2: (interlace: 32 blocks) Device Start Block Dbase Reloc c27t8d2s0 16384 No Yes c4t7d1s0 16384 No Yes Stripe 3: (interlace: 32 blocks) Device Start Block Dbase Reloc c10t7d0s0 32768 No Yes c11t5d0s0 32768 No Yes c12t2d1s0 32768 No Yes c14t1d0s0 32768 No Yes c15t8d1s0 32768 No Yes c17t3d0s0 32768 No Yes c18t6d1s0 32768 No Yes c19t4d1s0 32768 No Yes c1t5d0s0 32768 No Yes c2t6d1s0 32768 No Yes c3t4d1s0 32768 No Yes c5t2d1s0 32768 No Yes c6t1d0s0 32768 No Yes c8t3d0s0 32768 No Yes |
For more information, see metastat(1M).
The metarename command with the -x option can exchange the names of volumes that have a parent-child relationship. For more information, see How to Rename a Volume and the metarename(1M) man page.
Solaris Volume Manager enables you to rename most types of volumes at any time, subject to some constraints.
Renaming volumes or switching volume names is an administrative convenience for management of volume names. For example, you could arrange all file system mount points in a desired numeric range. You might rename volumes to maintain a naming scheme for your logical volumes or to allow a transactional volume to use the same name as the underlying volume had been using.
Before you rename a volume, make sure that it is not currently in use. For a file system, make sure it is not mounted or being used as swap. Other applications using the raw device, such as a database, should have their own way of stopping access to the data.
Specific considerations for renaming volumes include the following:
You can rename any volume except the following:
Soft partitions
Volumes on which soft partitions are directly built
Volumes that are being used as log devices
Hot spare pools
You can rename volumes within a disk set. However, you cannot rename volumes to move them from one disk set to another.
You can use either the Enhanced Storage tool within the Solaris Management Console or the command line (the metarename(1M) command) to rename volumes.
When used with the -x option, the metarename command exchanges the names of an existing layered volume with one of its subdevices. This exchange can occur between a mirror and one of its submirrors, or a transactional volume and its master device.
You must use the command line to exchange volume names. This functionality is currently unavailable in the Solaris Volume Manager GUI. However, you can rename a volume with either the command line or the GUI.
The metarename -x command can make it easier to mirror or unmirror an existing volume, and to create or remove a transactional volume of an existing volume.
You cannot rename a volume that is currently in use. This includes volumes that are used as mounted file systems, as swap, or as active storage for applications or databases. Thus, before you use the metarename command, stop all access to the volume being renamed. For example, unmount a mounted file system.
You cannot exchange volumes in a failed state, or volumes using a hot spare replacement.
An exchange can only take place between volumes with a direct parent-child relationship. You could not, for example, directly exchange a stripe in a mirror that is a master device with the transactional volume.
You must use the -f (force) flag when exchanging members of a transactional device.
You cannot exchange (or rename) a logging device. The workaround is to either detach the logging device, rename it, then reattach it to the transactional device; or detach the logging device and attach another logging device of the desired name.
Only volumes can be exchanged. You cannot exchange slices or hot spares.
Solaris Volume Manager transactional volumes do not support large volumes. In all cases, UFS logging (see mount_ufs(1M)
Check the volume name requirements (Volume Names), and Background Information for Renaming Volumes.
Unmount the file system that uses the volume.
To rename the volume, use one of the following methods:
From the Enhanced Storage tool within the Solaris Management Console, open the Volumes node and select the volume you want to rename. Right-click the icon and choose the Properties option, then follow the instructions on screen. For more information, see the online help.
Use the following format of the metarename command:
metarename old-volume-name new-volume-name |
old-volume-name is the name of the existing volume.
new-volume-name is the new name for the existing volume.
See metarename(1M) for more information.
Edit the /etc/vfstab file to refer to the new volume name, if necessary.
Remount the file system.
# umount /home # metarename d10 d100 d10: has been renamed to d100 (Edit the /etc/vfstab file so that the file system references the new volume) # mount /home |
In this example, the volume d10 is renamed to d100. Because d10 contains a mounted file system, the file system must be unmounted before the rename can occur. If the volume is used for a file system with an entry in the /etc/vfstab file, the entry must be changed to reference the new volume name. For example, the following line:
/dev/md/dsk/d10 /dev/md/rdsk/d10 /docs ufs 2 yes - |
should be changed to:
/dev/md/dsk/d100 /dev/md/rdsk/d100 /docs ufs 2 yes - |
Then, the file system should be remounted.
If you have an existing mirror or transactional volume, you can use the metarename -x command to remove the mirror or transactional volume and keep data on the underlying volume. For a transactional volume, as long as the master device is a volume (RAID 0, RAID 1, or RAID 5 volume), you can keep data on that volume.
Solaris Volume Manager configuration files contain basic Solaris Volume Manager information, as well as most of the data necessary to reconstruct a configuration. The following sections illustrate how to work with these files.
Once you have defined all appropriate parameters for the Solaris Volume Manager environment, use the metastat -p command to create the /etc/lvm/md.tab file.
# metastat -p > /etc/lvm/md.tab |
This file contains all parameters for use by the metainit, and metahs commands, in case you need to set up several similar environments or recreate the configuration after a system failure.
For more information about the md.tab file, see Overview of the md.tab File.
Use this procedure only if you have experienced a complete loss of your Solaris Volume Manager configuration, or if you have no configuration yet and you want to create a configuration from a saved configuration file.
If your system loses the information maintained in the state database (for example, because the system was rebooted after all state database replicas were deleted), and as long as no volumes were created since the state database was lost, you can use the md.cf or md.tab files to recover your Solaris Volume Manager configuration.
The md.cf file does not maintain information on active hot spares. Thus, if hot spares were in use when the Solaris Volume Manager configuration was lost, those volumes that were using active hot spares will likely be corrupted.
For more information about these files, see the md.cf(4) and the md.tab(4) man pages.
Create state database replicas.
See Creating State Database Replicas for more information.
Create, or update the /etc/lvm/md.tab file.
If you are attempting to recover the last known Solaris Volume Manager configuration, copy the md.cf file to the md.tab file.
If you are creating a new Solaris Volume Manager configuration based on a copy of the md.tab file that you preserved, put a copy of your preserved file at /etc/lvm/md.tab.
Edit the “new” md.tab file and do the following:
If you are creating a new configuration or recovering a configuration after a crash, configure the mirrors as one-way mirrors. If a mirror's submirrors are not the same size, be sure to use the smallest submirror for this one-way mirror. Otherwise data could be lost.
If you are recovering an existing configuration and Solaris Volume Manager was cleanly stopped, leave the mirror configuration as multi-way mirrors
Specify RAID 5 volumes with the -k option, to prevent reinitialization of the device. See the metainit(1M) man page for more information.
Check the syntax of the md.tab file entries without committing changes by using the following form of the metainit command:
# metainit -n -a component-name |
The metainit command does not maintain a hypothetical state of the devices that might have been created while running with the -n, so creating volumes that rely on other, nonexistent volumes will result in errors with the -n even though the command may succeed without the -n option.
-n specifies not to actually create the devices. Use this to check to verify that the results will be as you expect
-a specifies to activate the devices.
component-name specifies the name of the component to initialize. If no component is specified, all components will be created.
If no problems were apparent from the previous step, recreate the volumes and hot spare pools from the md.tab file:
# metainit -a component-name |
As needed, make the one-way mirrors into multi-way mirrors by using the metattach command.
Validate the data on the volumes.
The Solaris Volume Manager configuration has the following default values:
128 volumes per disk set
d0 through d127 as the namespace available for use by volumes
4 disk sets
State database replica maximum size of 8192 blocks
The default values of total volumes, namespace, and number of disk sets can be changed, if necessary. The tasks in this section tell you how to change these values.
The nmd field in the /kernel/drv/md.conf file allocates the number of volumes allowed and the namespace available for volumes. This task describes how to increase the number of volumes from the default value of 128 and the namespace from the default range of d0 through d127. If you need to configure more volumes than the default allows, you can increase this value up to 8192.
If you lower this number at any point, any volume existing between the old number and the new number might not be available, potentially resulting in data loss. If you see a message such as “md: d200: not configurable, check /kernel/drv/md.conf,” you must edit the md.conf file and increase the value, as explained in this task.
Review Prerequisites for Troubleshooting the System.
Change the value of the nmd field. Values up to 8192 are supported.
Save your changes.
Perform a reconfiguration reboot to build the volume names.
# reboot -- -r |
Here is a sample md.conf file that is configured for 256 volumes.
# #ident "@(#)md.conf 1.7 94/04/04 SMI" # # Copyright (c) 1992, 1993, 1994 by Sun Microsystems, Inc. # # #pragma ident "@(#)md.conf 2.1 00/07/07 SMI" # # Copyright (c) 1992-1999 by Sun Microsystems, Inc. # All rights reserved. # name="md" parent="pseudo" nmd=256 md_nsets=4; |
This task shows you how to increase the number of disk sets from the default value of 4.
Do not decrease the number of default disk sets if you have already configured disk sets. Lowering this number could make existing disk sets unavailable or unusable.
Edit the /kernel/drv/md.conf file.
Change the value of the md_nsets field. Values up to 32 are supported.
Save your changes.
# reboot -- -r |
Here is a sample md.conf file that is configured for five shared disk sets. The value of md_nsets is 6, which results in five shared disk sets and one local disk set.
# # #pragma ident "@(#)md.conf 2.1 00/07/07 SMI" # # Copyright (c) 1992-1999 by Sun Microsystems, Inc. # All rights reserved. # name="md" parent="pseudo" nmd=128 md_nsets=6; # Begin MDD database info (do not edit) ... # End MDD database info (do not edit) |
After a volume that contains a file system is expanded (more space is added), if that volume contains a UFS, you also need to “grow” the file system to recognize the added space. You must manually grow the file system with the growfs command. The growfs command expands the file system, even while mounted. However, write access to the file system is not possible while the growfs command is running.
An application, such as a database, that uses the raw device must have its own method to grow added space. Solaris Volume Manager does not provide this capability.
The growfs command will “write-lock” a mounted file system as it expands the file system. The length of time the file system is write-locked can be shortened by expanding the file system in stages. For instance, to expand a 1 Gbyte file system to 2 Gbytes, the file system can be grown in 16 Mbyte stages using the -s option to specify the total size of the new file system at each stage.
During the expansion, the file system is not available for write access because of write-lock. Write accesses are transparently suspended and are restarted when the growfs command unlocks the file system. Read accesses are not affected, though access times are not kept while the lock is in effect.
Solaris Volume Manager volumes can be expanded, but not shrunk.
A volume, regardless if it is used for a file system, application, or database, can be expanded. So, you can expand RAID 0 (stripe and concatenation) volumes, RAID 1 (mirror) volumes, and RAID 5 volumes as well as soft partitions.
You can concatenate a volume that contains an existing file system while the file system is in use. Then, as long as the file system is UFS, it can be expanded (with the growfs command) to fill the larger space without interrupting read access to the data.
Once a file system is expanded, it cannot be shrunk, due to constraints in UFS.
Applications and databases that use the raw device must have their own method to “grow” the added space so that they can recognize it. Solaris Volume Manager does not provide this capability.
When a component is added to a RAID 5 volume, it becomes a concatenation to the device. The new component does not contain parity information. However, data on the new component is protected by the overall parity calculation that takes place for the volume.
You can expand a log device by adding additional components. You do not need to run the growfs command, as Solaris Volume Manager automatically recognizes the additional space on reboot.
Soft partitions can be expanded by adding space from the underlying volume or slice. All other volumes can be expanded by adding slices.
Check Prerequisites for Creating Solaris Volume Manager Components.
Use the growfs command to grow a UFS on a logical volume.
# growfs -M /mount-point /dev/md/rdsk/volumename |
See the following example and the growfs(1M) man page for more information.
# df -k Filesystem kbytes used avail capacity Mounted on ... /dev/md/dsk/d10 69047 65426 0 100% /home2 ... # growfs -M /home2 /dev/md/rdsk/d10 /dev/md/rdsk/d10: 295200 sectors in 240 cylinders of 15 tracks, 82 sectors 144.1MB in 15 cyl groups (16 c/g, 9.61MB/g, 4608 i/g) super-block backups (for fsck -F ufs -o b=#) at: 32, 19808, 39584, 59360, 79136, 98912, 118688, 138464, 158240, 178016, 197792, 217568, 237344, 257120, 276896, # df -k Filesystem kbytes used avail capacity Mounted on ... /dev/md/dsk/d10 138703 65426 59407 53% /home2 ... |
In this example, a new slice was added to a volume, d10, which contains the mounted file system /home2. The growfs command specifies the mount point with the -M option to be /home2, which is expanded onto the raw volume /dev/md/rdsk/d10. The file system will span the entire volume when the growfs command is complete. You can use the df -hk command before and after to verify the total disk capacity.
For mirror and transactional volumes, always run the growfs command on the top-level volume, not a submirror or master device, even though space is added to the submirror or master device.
Solaris Volume Manager has the capability to replace and enable components within RAID 1 (mirror) and RAID 5 volumes.
In Solaris Volume Manager terms, replacing a component is a way to substitute an available component on the system for a selected component in a submirror or RAID 5 volume. You can think of this process as logical replacement, as opposed to physically replacing the component. (See Replacing a Component With Another Available Component.)
Enabling a component means to “activate” or substitute a component with itself (that is, the component name is the same). See Enabling a Component.
When recovering from disk errors, scan /var/adm/messages to see what kind of errors occurred. If the errors are transitory and the disks themselves do not have problems, try enabling the failed components. You can also use the format command to test a disk.
You can enable a component when any of the following conditions exist:
Solaris Volume Manager could not access the physical drive. This problem might have occurred, for example, due to a power loss, or a loose drive cable. In this case, Solaris Volume Manager puts the components in the “Maintenance” state. You need to make sure that the drive is accessible (restore power, reattach cables, and so on), and then enable the components in the volumes.
You suspect that a physical drive is having transitory problems that are not disk-related. You might be able to fix a component in the “Maintenance” state by simply enabling it. If this does not fix the problem, then you need to either physically replace the disk drive and enable the component, or replace the component with another available component on the system.
When you physically replace a drive, be sure to partition it like the old drive to ensure adequate space on each used component.
Always check for state database replicas and hot spares on the drive being replaced. Any state database replica shown to be in error should be deleted before replacing the disk. Then after enabling the component, they should be recreated (at the same size). You should treat hot spares in the same manner.
You use the metareplace command when you replace or swap an existing component with a different component that is available and not in use on the system.
You can use this command when any of the following conditions exist:
A disk drive has problems, and you do not have a replacement drive, but you do have available components elsewhere on the system.
You might want to use this strategy if a replacement is absolutely necessary but you do not want to shut down the system.
You are seeing soft errors.
Physical disks might report soft errors even though Solaris Volume Manager shows the mirror/submirror or RAID 5 volume in the “Okay” state. Replacing the component in question with another available component enables you to perform preventative maintenance and potentially prevent hard errors from occurring.
You want to do performance tuning.
For example, by using the performance monitoring feature available from the Enhanced Storage tool within the Solaris Management Console, you see that a particular component in a RAID 5 volume is experiencing a high load average, even though it is in the “Okay” state. To balance the load on the volume, you can replace that component with a component from a disk that is less utilized. You can perform this type of replacement online without interrupting service to the volume.
When a component in a mirror or RAID 5 volume experiences errors, Solaris Volume Manager puts the component in the “Maintenance” state. No further reads or writes are performed to a component in the “Maintenance” state. Subsequent errors on other components in the same volume are handled differently, depending on the type of volume. A RAID 1 volume might be able to tolerate many components in the “Maintenance” state and still be read from and written to. A RAID 5 volume, by definition, can only tolerate a single component in the “Maintenance” state.
When a component in a RAID 0 or RAID 5 volume experiences errors and there are no redundant components to read from (for example, in a RAID 5 volume, after one component goes into Maintenance state, there is no redundancy available, so the next component to fail would go into “Last Erred” state) When either a mirror or RAID 5 volume has a component in the “Last Erred” state, I/O is still attempted to the component marked “Last Erred.” This happens because a “Last Erred” component contains the last good copy of data from Solaris Volume Manager's point of view. With a component in the “Last Erred” state, the volume behaves like a normal device (disk) and returns I/O errors to an application. Usually, at this point some data has been lost.
Always replace components in the “Maintenance” state first, followed by those in the “Last Erred” state. After a component is replaced and resynchronized, use the metastat command to verify its state, then validate the data to make sure it is good.
Mirrors –If components are in the “Maintenance” state, no data has been lost. You can safely replace or enable the components in any order. If a component is in the “Last Erred” state, you cannot replace it until you first replace all the other mirrored components in the “Maintenance” state. Replacing or enabling a component in the “Last Erred” state usually means that some data has been lost. Be sure to validate the data on the mirror after you repair it.
RAID 5 Volumes–A RAID 5 volume can tolerate a single component failure. You can safely replace a single component in the “Maintenance” state without losing data. If an error on another component occurs, it is put into the “Last Erred” state. At this point, the RAID 5 volume is a read-only device. You need to perform some type of error recovery so that the state of the RAID 5 volume is stable and the possibility of data loss is reduced. If a RAID 5 volume reaches a “Last Erred” state, there is a good chance it has lost data. Be sure to validate the data on the RAID 5 volume after you repair it.
When you replace components in a mirror or a RAID 5 volume, follow these guidelines:
Always replace components in the “Maintenance” state first, followed by those components in the “Last Erred” state.
After a component is replaced and resynchronized, use the metastat command to verify the volume's state, then validate the data to make sure it is good. Replacing or enabling a component in the “Last Erred” state usually means that some data has been lost. Be sure to validate the data on the volume after you repair it. For a UFS, run the fsck command to validate the “metadata” (the structure of the file system) then check the actual user data. (Practically, users will have to examine their files.) A database or other application must have its own way of validating its internal data structure.
Always check for state database replicas and hot spares when you replace components. Any state database replica shown to be in error should be deleted before you replace the physical disk. The state database replica should be added back before enabling the component. The same procedure applies to hot spares.
RAID 5 volumes – During component replacement, data is recovered, either from a hot spare currently in use, or using the RAID level 5 parity, when no hot spare is in use.
RAID 1 volumes – When you replace a component, Solaris Volume Manager automatically starts resynchronizing the new component with the rest of the mirror. When the resynchronization completes, the replaced component becomes readable and writable. If the failed component has been replaced with data from a hot spare, the hot spare is placed in the “Available” state and made available for other hot spare replacements.
The new component must be large enough to replace the old component.
As a precaution, back up all data before you replace “Last Erred” devices.
A submirror or RAID 5 volume might be using a hot spare in place of a failed component. When that failed component is enabled or replaced by using the procedures in this section, the hot spare is marked “Available” in the hot spare pool, and is ready for use.
