You should have the following information on hand when you troubleshoot Solaris Volume Manager problems:
Output from the metadb command.
Output from the metastat command.
Output from the metastat -p command.
Backup copy of the /etc/vfstab file.
Backup copy of the /etc/lvm/mddb.cf file.
Disk partition information, from the prtvtoc command (SPARC® systems) or the fdisk command (x86–based systems)
Solaris version
Solaris patches installed
Solaris Volume Manager patches installed
Any time you update your Solaris Volume Manager configuration, or make other storage or operating system-related changes to your system, generate fresh copies of this configuration information. You could also generate this information automatically with a cron job.
