In the following example, root (/) is mirrored with a two-way mirror, d0. The root (/) entry in the /etc/vfstab file has somehow reverted back to the original slice of the file system, but the information in the /etc/system file still shows booting to be from the mirror d0. The most likely reason is that the metaroot command was not used to maintain the /etc/system and /etc/vfstab files, or an old copy of the/etc/vfstab file was copied back.
The incorrect /etc/vfstab file would look something like the following:
#device device mount FS fsck mount mount #to mount to fsck point type pass at boot options # /dev/dsk/c0t3d0s0 /dev/rdsk/c0t3d0s0 / ufs 1 no - /dev/dsk/c0t3d0s1 - - swap - no - /dev/dsk/c0t3d0s6 /dev/rdsk/c0t3d0s6 /usr ufs 2 no - # /proc - /proc proc - no - swap - /tmp tmpfs - yes - |
Because of the errors, you automatically go into single-user mode when the system is booted:
ok boot ... configuring network interfaces: hme0. Hostname: lexicon mount: /dev/dsk/c0t3d0s0 is not this fstype. setmnt: Cannot open /etc/mnttab for writing INIT: Cannot create /var/adm/utmp or /var/adm/utmpx INIT: failed write of utmpx entry:" " INIT: failed write of utmpx entry:" " INIT: SINGLE USER MODE Type Ctrl-d to proceed with normal startup, (or give root password for system maintenance): <root-password> |
At this point, root (/) and /usr are mounted read-only. Follow these steps:
Run the fsck command on the root (/) mirror.
Be careful to use the correct volume for root.
# fsck /dev/md/rdsk/d0 ** /dev/md/rdsk/d0 ** Currently Mounted on / ** Phase 1 - Check Blocks and Sizes ** Phase 2 - Check Pathnames ** Phase 3 - Check Connectivity ** Phase 4 - Check Reference Counts ** Phase 5 - Check Cyl groups 2274 files, 11815 used, 10302 free (158 frags, 1268 blocks, 0.7% fragmentation) |
Remount root (/) read/write so you can edit the /etc/vfstab file.
# mount -o rw,remount /dev/md/dsk/d0 / mount: warning: cannot lock temp file </etc/.mnt.lock> |
Run the metaroot command.
# metaroot d0 |
This command edits the /etc/system and /etc/vfstab files to specify that the root (/) file system is now on volume d0.
Verify that the /etc/vfstab file contains the correct volume entries.
The root (/) entry in the /etc/vfstab file should appear as follows so that the entry for the file system correctly references the RAID 1 volume:
#device device mount FS fsck mount mount #to mount to fsck point type pass at boot options # /dev/md/dsk/d0 /dev/md/rdsk/d0 / ufs 1 no - /dev/dsk/c0t3d0s1 - - swap - no - /dev/dsk/c0t3d0s6 /dev/rdsk/c0t3d0s6 /usr ufs 2 no - # /proc - /proc proc - no - swap - /tmp tmpfs - yes - |
Reboot the system.
The system returns to normal operation.
