System Administration Guide: Basic Administration
Chapter 5 Managing Server and Client Support (Overview)
This chapter describes the management of server and client support on a network, and it provides overview information about each system configuration (referred to as a system type) that is supported in the Solaris environment. This chapter also includes guidelines for selecting the appropriate system type to meet your needs.
This is a list of the overview information in this chapter.
For step-by-step instructions about how to manage diskless client support, see Chapter 6, Managing Diskless Clients (Tasks).
What's New in Server and Client Management?
This section describes new server and client management features in the Solaris 9 release.
Diskless Client Support
In this Solaris release, you can manage diskless clients with the smosservice and smdiskless commands. Diskless clients are systems with no disks that depend on servers for all their services.
These commands are part of the Solaris Management Console tool suite. You cannot use the Solaris Management Console to manage diskless clients. You can only use the smosservice and smdiskless commands to manage diskless clients.
For more information on managing diskless clients, see Diskless Client Management Overview and Chapter 6, Managing Diskless Clients (Tasks).
Where to Find Server and Client Tasks
Use this table to find step-by-step instructions for setting up server and client support.
Server/Client Services
For More Information
Install or JumpStart clients
Solaris 9 9/04 Installation Guide
Diskless client systems in the Solaris 9 environment
Diskless client systems in previous Solaris releases
Solstice AdminSuite 2.3 Administration Guide
What Are Servers, Clients, and Appliances?
Systems on the network can usually be described as one of the following:
System Type
Description
Server
A system that provides services to other systems in its network. There are file servers, boot servers, web servers, database servers, license servers, print servers, installation servers, appliance servers, and even servers for particular applications. This chapter uses the term server to mean a system that provides boot services and file systems for other systems on the network.
Client
A system that uses remote services from a server. Some clients have no disk storage capacity and they have to rely on remote file systems from a server to function. Diskless systems and appliance systems are examples of this type of client.
Other clients might use remote services (such as installation software) from a server, but they don't rely on a server to function. A standalone system, which has its own hard disk containing the root (/), /usr, and /export/home file systems and swap space, is a good example of this type of client.
Appliance
A network appliance such as the Sun Ray appliance provides access to applications and the Solaris environment. An appliance gives you centralized server administration and no client administration or upgrades. Sun Ray appliances also provide hot desking, which is the ability to instantly access your computing session from any appliance in the server group, exactly where you left off. For more information, see http://www.sun.com/products/sunray.
What Does Client Support Mean?
Support for a client means providing software and services to help the client function. Support can include the following:
Overview of System Types
System types are sometimes defined by how they access the root (/) and /usr file systems, including the swap area. For example, standalone systems and server systems mount these file systems from a local disk, while other clients mount the file systems remotely, relying on servers to provide these services. This table lists some of the characteristics of each system type.
Table 5–1 Characteristics of General System Types
System Type
Local File Systems
Local Swap?
Remote File Systems
Network Use
Relative Performance
Server
root (/)
/usr
/home
/opt
/export/home
/export/root
Yes
– None –
High
High
Standalone System
root (/)
/usr
/export/home
Yes
– None –
Low
High
Diskless Client
– None –
No
root (/)
swap
/usr
/home
High
Low
Appliance
None
None
None
High
High
Servers
A server system contains the following file systems:
Servers can also contain the following software to support other systems:
Standalone Systems
A networked standalone system can share information with other systems in the network, but it can continue to function if detached from the network.
A standalone system can function autonomously because it has its own hard disk that contains the root (/), /usr, and /export/home file systems and swap space. The standalone system thus has local access to operating system software, executables, virtual memory space, and user-created files.
Note –
A standalone system requires sufficient disk space to hold its necessary file systems.
A non-networked standalone system is a standalone system with all the characteristics listed above, except it is not connected to a network.
Diskless Clients
A diskless client has no disk and depends on a server for all its software and storage needs. A diskless client remotely mounts its root (/), /usr, and /home file systems from a server.
A diskless client generates significant network traffic due to its continual need to procure operating system software and virtual memory space from across the network. A diskless client cannot operate if it is detached from the network or if its server malfunctions.
For more overview information about diskless clients, see Diskless Client Management Overview.
Appliances
An appliance, such as the Sun Ray appliance, is an X display device that requires no administration. There is no CPU, fan, disk, and very little memory. An appliance is connected to a Sun display monitor, but the appliance user's desktop session is run on a server and displayed back to the user. The X environment is setup automatically for the user and has the following characteristics:
Guidelines for Choosing System Types
You can determine which system types are appropriate for your environment by comparing each system type based on the following characteristics:
This table describes how each system type scores in terms of each category. A ranking of 1 is most efficient. A ranking of 4 is least efficient.
Table 5–2 Comparison of System Types
System Type
Centralized Administration
Performance
Disk Usage
Standalone System
4
1
4
Diskless Client
1
4
1
Appliance
1
1
1
The following sections and Chapter 6, Managing Diskless Clients (Tasks) describe how to manage diskless client support in the Solaris 9 release.
A diskless client is a system that depends on an OS server for its operating system, software, and storage. A diskless client mounts its root (/), /usr, and other file systems from its OS server. A diskless client has its own CPU and physical memory and can process data locally. However, a diskless client cannot operate if it is detached from its network or if its OS server malfunctions. A diskless client generates significant network traffic because of its continual need to function across the network.
In previous Solaris releases, diskless clients were managed with the Solstice graphical management tools. In the Solaris 9 release, the diskless client commands, smosservice and smdiskless, enable you to manage OS services and diskless client support.
OS Server and Diskless Client Support Information
The following table describes which Solaris releases and architecture types are supported by the smosservice and smdiskless commands.
Architecture Type
Solaris 2.6
Solaris 7
Solaris 8 1/01, 4/01, 7/01, 10/01, 2/02
Solaris 9
SPARC Servers
Supported
Supported
Supported
Supported
x86 Servers
Supported
Supported
Supported
Supported
SPARC Clients
Supported
Supported
Supported
Supported
x86 Clients
Not Supported
Not Supported
Not Supported
Supported
This table describes the combination of OS server-client configurations that are supported by the smosservice and smdiskless commands.
Solaris 2.6 Release Support
Solaris 7 Release Support
Solaris 8 1/01, 4/01, 7/01, 10/01, 2/02 Support
Solaris 9 Support
OS Server-Client OS Release
Solaris 2.6–Solaris 2.6
Solaris 7–Solaris 2.6, or 7
Solaris 8 1/01, 4/01, 7/01, 10/01, 2/02–Solaris 2.6, 7, or 8 1/01, 4/01, 7/01, 10/01, 2/02
Solaris 9–Solaris 2.6, 7, 8 1/01, 4/01, 7/01, 10/01, 2/02
Diskless Client Management Features
You can use the smosservice and smdiskless commands to add and maintain diskless client support on a network. By using a name service, you can manage system information in a centralized manner so that important system information, such as host names, does not have to be duplicated on every system in the network.
You can do the following tasks with the smosservice and smdiskless commands:
You can only use the diskless client commands to set up diskless client booting. You cannot use them to set up other services, such as remote installation or profile services. Set up remote installation services by including diskless client specifications in the sysidcfg file. For more information, see Solaris 9 9/04 Installation Guide.
Working With Diskless Client Commands
By writing your own shell scripts and using the commands shown in the following table, you can easily set up and manage your diskless client environment.
Table 5–3 Diskless Client Commands
Command
Subcommand
Task
/usr/sadm/bin/smosservice
add
Add OS services
delete
Delete OS services
list
List OS services
patch
Manage OS service patches
/usr/sadm/bin/smdiskless
add
Add a diskless client to an OS server
delete
Delete a diskless client from an OS server
list
List the diskless clients on an OS server
modify
Modify the attributes of a diskless client
You can obtain help on these commands in two ways:
Required RBAC Rights for Diskless Client Management
You can use the smosservice and smdiskless commands as superuser. If you are using Role-Based Access Control (RBAC), you can use of either a subset or all of the diskless client commands, according to the RBAC rights to which they are assigned. The following table lists the RBAC rights that are required to use the diskless client commands.
Table 5–4 Required Rights For Diskless Client Management
RBAC Right
Command
Task
Basic Solaris User, Network Management
smosservice list
List OS services
smosservice patch
List OS services patches
smdiskless list
List diskless clients
Network Management
smdiskless add
Add diskless clients
System Administrator
All commands
All tasks
Adding OS Services
A Solaris OS server is a server that provides operating system (OS) services to support diskless client systems. You can add support for an OS server or convert a standalone system to an OS server with the smosservice command.
For each platform group and Solaris release that you want to support, you must add the particular OS service to the OS server. For example, if you want to support SPARC Sun4m systems running the Solaris 8 release, you must add Sun4m/Solaris 8 OS services to the OS server. You would also still need to add OS services to support SPARC Sun4c systems or x86 based systems that runs the Solaris 8 release, because they are different platform groups.
You must have access to the appropriate Solaris CD or disk image to add OS services.
Adding OS Services When the OS Server Has Been Patched
When adding OS services to an OS server, you might see error messages saying that you have inconsistent versions of the OS running on the server and the OS that you are trying to add. This message occurs when the installed version of the OS has packages that were previously patched and the OS services being added do not have those packages patched (because the patches have been integrated into the packages).
For example, you may have a server that is running the Solaris 7 release. You may also have additional OS services loaded on this server, including the Solaris 2.6 SPARC sun4m OS services that have been patched. If you try to add the Solaris 2.6 SPARC sun4c OS services from a CD-ROM to this server, you could get the following error message:
Error: inconsistent revision, installed package appears to have been
patched resulting in it being different than the package on your media.
You will need to backout all patches that patch this package before
retrying the add OS service option.
Disk Space Requirements for OS Servers
Before you set up your diskless client environment, make sure you have the required disk space available for each diskless client directory.
In previous Solaris releases, you were prompted about diskless client support during the installation process. In the Solaris 9 release, you must manually allocate an /export file system either during installation or create it after installation. See the following table for specific disk space requirements.
Table 5–5 Disk Space Requirements for OS Servers
Directory
Required Space in Mbytes
/export/Solaris_version
10
/export/exec
800
/export/share
5
/export/swap/diskless_client
32 (default size)
/export/dump/diskless_client
32 (default size)
/export/root/templates/Solaris_version
30
/export/root/clone/Solaris_version/
machine_class
30 through 60 (depends on machine class)
/export/root/diskless_client (clone of above)
/tftpboot/inetboot.machine_class.Solaris_
version
200 Kbytes per machine_class.Solaris_version
