These sections describe the procedures needed to manage diskless clients.
Keep the following key points in mind when managing diskless clients:
The Solaris installation program doesn't prompt you to set up diskless client support. You must manually create an /export partition to support diskless clients. You create the /export partition during or after the installation process.
The /export partition must contains a minimum of 800–1000 Mbytes, depending upon the number of clients supported. For specific information, see Disk Space Requirements for OS Servers.
The name service identified in the smosservice or smdiskless commands must match the primary name service identified in the /etc/nsswitch.conf file. If you don't specify a name service in the smdiskless or smosservice commands, the default name service is files.
After you determine the platform, media path, and cluster for each diskless client, you are ready to add OS services. The following directories are created and populated for each OS service that you add:
/export/Solaris_version/Solaris_version_instruction_set.all (symbolic link to /export/exec/Solaris_version/Solaris_version_instruction_set.all)
/export/Solaris_version/var
/export/Solaris_version/opt
/export/share
/export/root/templates/Solaris_version
/export/root/clone
/export/root/clone/Solaris_version
/export/root/clone/Solaris_version/machine_class
The following default directories are created and populated on the OS server for each diskless client that you add:
/export/root/diskless_client
/export/swap/diskless_client
/tftpboot/diskless_client_ipaddress_in_hex/export/dump/diskless_client (if you specify the -x dump option)
You can modify the default locations of the root, /swap, and /dump directories by using the -x option. However, do not create these directories under the /export file system.
Make sure that the system intended to be the OS service is running a supported release. Also verify that the combination of OS server release and diskless client release is supported.
When you use the smosservice add command to add OS services, you must specify the platform, mediapath, and cluster (or software group) of each diskless client platform that you want to support.
Verify that the intended OS server and diskless client will be running a combination of Solaris releases that are supported.
For more information, see OS Server and Diskless Client Support Information.
Identify the diskless client platform by using this format:
instruction_set.machine_class.Solaris_version
For example:
sparc.sun4u.Solaris_9
The following are the possible platform options:
| instruction_set | machine_class | Solaris_version |
| sparc | sun4d*, sun4c*, sun4m*, sun4u, | Solaris_9, Solaris_8, Solaris_2.7, Solaris_2.6 |
| i386 | i86pc | Solaris_9, Solaris_8, Solaris_2.7, Solaris_2.6 |
* The sun4c architecture is not supported in the Solaris 8 or Solaris 9 releases. The sun4d architecture is not supported in the Solaris 9 releases.
Identify the media path, which is the full path to the disk image that contains the operating system that you want to install for the diskless client.
The Solaris operating system is delivered on multiple CDs. However, you cannot use the smosservice command to load OS services from a multiple CD distribution. You must run the scripts that are found on the Solaris software CDs (and optional Language CD) to do the following:
Create an install image on a server. For information on setting up an install server, refer to Solaris 9 9/04 Installation Guide.
Load the required OS services from the CD image using one of the following scripts:
CD 1 of 2 – /cdrom/cdrom0/s0/Solaris_9/Tools/setup_install_server
CD 2 of 2 – /cdrom/cdrom0/s0/Solaris_9/Tools/add_to_install_server
Language CD – /cdrom/cdrom0/s0/Solaris_9/Tools/add_to_install_server
For example, if you are using the setup_install_server script from the Solaris 9 Software 1 of 2 SPARC Platform Edition CD on a locally connected CD-ROM device, the syntax looks something like this:
| # mkdir /export/install/sparc_9 # cd /cd_mount_point/Solaris_9/Tools # ./setup_install_server /export/install/sparc_9 |
After the Solaris CD image is installed on the disk, specify the disk image path. For example:
| /net/export/install/sparc_9 |
Identify the SUNWCXall cluster when you add OS services.
You must use the same cluster for diskless clients that run the same operating system on the same system (SPARC or x86).
For example, consider the following diskless clients:
sparc.sun4m.Solaris_9
To set up these diskless clients, you would need to specify the SUNWCXall cluster for each diskless client because the sun4u and sun4m systems require the SUNWCXall cluster. In addition, diskless clients that run the same operating release (in this situation, Solaris_9) on the same system must use the same cluster.
If you are using a sun4u system, or if you are using a system with an accelerated 8-bit color memory frame buffer (cgsix), you must specify SUNWCXall as the cluster.
Use this procedure to add OS services for a diskless client on the server.
Become superuser or assume an equivalent role on the server.
For more information, see How to Become Superuser (root) or Assume a Role.
Verify that the Solaris Management Console server is running and that the diskless client tools are available on the system.
| # /usr/sadm/bin/smosservice list -H starbug:898 -- Loading Tool: com.sun.admin.osservermgr.cli.OsServerMgrCli from ... Login to starbug as user root was successful. Download of com.sun.admin.osservermgr.cli.OsServerMgrCli from starbug:898 was successful. Platform ------------------------------------------------------------------------- |
| # /usr/sadm/bin/smosservice add -H hostname:898 -- -o hostname -x mediapath=path -x platform=instruction-set.machine-class.Solaris-version -x cluster=cluster-name -x locale=locale-name |
| add | Adds the specified OS service. |
| -H hostname:898 | Specifies the host name and port to which you want to connect. If you do not specify a port, the system connects to the default port, 898. |
| -- | Identifies that the subcommand arguments start after this point. |
| -x mediapath=path | Specifies the full path to the Solaris image. |
| -x platform=instruction-set.machine-class.Solaris-version | Specifies the instruction architecture, machine class, and the Solaris version to be added. |
| -x cluster=cluster-name | Specifies the Solaris cluster to install. |
| -x locale=locale-name | Specifies the locale to install. |
The installation process can take approximately 45 minutes, depending on the server speed and the OS service configuration you choose.
For more information, see smosservice(1M).
(Optional) Continue to add the other OS services.
When you are finished adding OS services, verify that the OS services were installed.
| # /usr/sadm/bin/smosservice list -H hostname:898 -- |
This example describes how to add Solaris 8 OS services on the server starbug. The server starbug is running the Solaris 9 release.
| # /usr/sadm/bin/smosservice add -H starbug:898 -- -o starbug -x mediapath=/net/install/export/sparc_8 -x platform=sparc.sun4u.Solaris_8 -x cluster=SUNWCXall -x locale=en_US Authenticating as user: root Type /? for help, pressing enter accepts the default denoted by [ ] Please enter a string value for: password :: xxx Loading Tool: com.sun.admin.osservermgr.cli.OsServerMgrCli from starbug:898 Login to starbug as user root was successful. Download of com.sun.admin.osservermgr.cli.OsServerMgrCli from starbug:898 was successful. |
Use this procedure to add a diskless client after you have added OS services.
Become superuser or assume an equivalent role.
Add the diskless client.
| # /usr/sadm/bin/smdiskless add -- -i ip-address -e ethernet-address -n client-name -x os=instruction-set.machine-class.Solaris-version -x root=/export/root/client-name -x swap=/export/swap/client-name -x swapsize=size -x tz=timezone -x locale=locale-name |
| add | Adds the specified diskless client. |
| -- | Identifies that the subcommand arguments start after this pont. |
| -i ip-address | Identifies the IP address of the diskless client. |
| -e ethernet-address | Identifies the Ethernet address of the diskless client. |
| -n client-name | Specifies the name of the diskless client. |
| -x os=instruction-set.machine-class.Solaris-version | Specifies the instruction architecture, machine class, OS, and the Solaris version for the diskless client. |
| -x root=root=/export/root/client-name | Identifies the root directory for the diskless client. |
| -x swap=root=/export/root/client-name | Identifies the swap file for the diskless client. |
| -x swapsize=size | Specifies the size of the swap file in Mbytes. The default is 24 Mbytes. |
| -x tz=timezone | Specifies the timezone for the diskless client. |
| -x locale=locale-name | Specifies the locale to install for the diskless client. |
For more information, see smdiskless(1M).
(Optional) Continue to use the smdiskless add command to add each diskless client.
Verify that the diskless clients were installed.
This example shows how to add a Solaris 8 client, holoship, from the server starbug.
| # /usr/sadm/bin/smdiskless add -- -i 172.20.27.103 -e 8:0:20:92:4e:f3 -n holoship -x os=sparc.sun4u.Solaris_8 -x root=/export/root/holoship -x swap=/export/swap/holoship -x swapsize=128 -x tz=US/Mountain -x locale=en_US |
This example shows how to add a Solaris 7 client, inquisitor, from the server starbug.
| # /usr/sadm/bin/smdiskless add -- -i 172.20.27.102 -e 8:0:20:1f:31:be -n inquisitor -x os=sparc.sun4u.Solaris_2.7 -x root=/export/root/inquisitor -x swap=/export/swap/inquisitor -x swapsize=64 -x tz=US/Mountain |
Verify the following prerequisites on the OS server:
Confirm that the name service used to add the diskless client and the OS services matches the primary name in the server's /etc/nsswitch.conf file.
Otherwise, the diskless client won't boot.
Confirm that the rpc.bootparamd daemon is running. If it is not running, start it.
Boot the diskless client.
| ok boot net |
Remove the diskless client support.
| # /usr/sadm/bin/smdiskless delete -- -o hostname:898 -n client-name |
Verify that the diskless client support is removed.
This example shows how to delete the diskless client holoship from the OS server starbug.
| # /usr/sadm/bin/smdiskless delete -- -o starbug -n holoship Authenticating as user: root Type /? for help, pressing enter accepts the default denoted by [ ] Please enter a string value for: password :: Starting SMC server version 2.0.0. endpoint created: :898 SMC server is ready. Loading Tool: com.sun.admin.osservermgr.cli.OsServerMgrCli from starbug Login to starbug as user root was successful. Download of com.sun.admin.osservermgr.cli.OsServerMgrCli from starbug was successful. |
Remove the OS services for the diskless clients.
| # /usr/sadm/bin/smosservice delete -H hostname:898 -- -x rmplatform=instruction-set.machine-class.Solaris-version |
Verify that the OS services are removed.
The following example shows how to delete the diskless client OS services (sparc.all.Solaris_9) from the server starbug.
| # /usr/sadm/bin/smosservice delete -H starbug:898 -- -x rmplatform=sparc.all.Solaris_9 Authenticating as user: root Type /? for help, pressing enter accepts the default denoted by [ ] Please enter a string value for: password :: Loading Tool: com.sun.admin.osservermgr.cli.OsServerMgrCli from starbug:898 Login to starbug as user root was successful. Download of com.sun.admin.osservermgr.cli.OsServerMgrCli from starbug:898 was successful. |
