Make sure that the system intended to be the OS service is running a supported release. Also verify that the combination of OS server release and diskless client release is supported.
When you use the smosservice add command to add OS services, you must specify the platform, mediapath, and cluster (or software group) of each diskless client platform that you want to support.
Verify that the intended OS server and diskless client will be running a combination of Solaris releases that are supported.
For more information, see OS Server and Diskless Client Support Information.
Identify the diskless client platform by using this format:
instruction_set.machine_class.Solaris_version
For example:
sparc.sun4u.Solaris_9
The following are the possible platform options:
instruction_set |
machine_class |
Solaris_version |
sparc |
sun4d*, sun4c*, sun4m*, sun4u, |
Solaris_9, Solaris_8, Solaris_2.7, Solaris_2.6 |
i386 |
i86pc |
* The sun4c architecture is not supported in the Solaris 8 or Solaris 9 releases. The sun4d architecture is not supported in the Solaris 9 releases.
Identify the media path, which is the full path to the disk image that contains the operating system that you want to install for the diskless client.
The Solaris operating system is delivered on multiple CDs. However, you cannot use the smosservice command to load OS services from a multiple CD distribution. You must run the scripts that are found on the Solaris software CDs (and optional Language CD) to do the following:
Create an install image on a server. For information on setting up an install server, refer to Solaris 9 9/04 Installation Guide.
Load the required OS services from the CD image using one of the following scripts:
CD 1 of 2 – /cdrom/cdrom0/s0/Solaris_9/Tools/setup_install_server
CD 2 of 2 – /cdrom/cdrom0/s0/Solaris_9/Tools/add_to_install_server
Language CD – /cdrom/cdrom0/s0/Solaris_9/Tools/add_to_install_server
For example, if you are using the setup_install_server script from the Solaris 9 Software 1 of 2 SPARC Platform Edition CD on a locally connected CD-ROM device, the syntax looks something like this:
# mkdir /export/install/sparc_9 # cd /cd_mount_point/Solaris_9/Tools # ./setup_install_server /export/install/sparc_9 |
After the Solaris CD image is installed on the disk, specify the disk image path. For example:
/net/export/install/sparc_9 |
Identify the SUNWCXall cluster when you add OS services.
You must use the same cluster for diskless clients that run the same operating system on the same system (SPARC or x86).
For example, consider the following diskless clients:
sparc.sun4m.Solaris_9
To set up these diskless clients, you would need to specify the SUNWCXall cluster for each diskless client because the sun4u and sun4m systems require the SUNWCXall cluster. In addition, diskless clients that run the same operating release (in this situation, Solaris_9) on the same system must use the same cluster.
If you are using a sun4u system, or if you are using a system with an accelerated 8-bit color memory frame buffer (cgsix), you must specify SUNWCXall as the cluster.
