Run Levels
A system's run level (also known as an init state) defines what services and resources are available to
users. A system can be in only one run level at a time.
The Solaris environment has eight run levels, which are described in
the following table. The default run level is specified in the /etc/inittab file as run level 3.
Table 8–1 Solaris Run Levels
Run Level
Init State
Type
Purpose
0
Power-down state
Power-down
To shut down the operating system so that it is safe to turn off power to
the system.
s or S
Single-user
state
Single-user
To run as a single user with some file systems mounted and accessible.
1
Administrative state
Single-user
To access all available file systems. User logins are disabled.
2
Multiuser state
Multiuser
For normal
operations. Multiple users can access the system and all file system. All
daemons are running except for the NFS server daemons.
3
Multiuser level with NFS resources shared
Multiuser
For normal operations with NFS resources shared. This is
the default run level for the Solaris environment.
4
Alternative multiuser state
Currently unavailable.
5
Power-down state
Power-down
To shut down
the operating system so that it is safe to turn off power to the system. If
possible, automatically turns off power on systems that support this feature.
6
Reboot state
Reboot
To shut down the
system to run level 0, and then reboot to multiuser level with NFS resources
shared (or whatever level is the default in the inittab
file).
How to Determine a System's Run Level
Display run level information by using the who -r
command.
Use the who -r command to determine a system's current
run level for any level, except run level 0.
Example—Determining a System's Run Level
This example displays information a system's current run level and information
about previous run levels.
$ who -r
. run-level 31 Dec 13 10:102 33 04 S5
Identifies the current run level
Identifies the date of last run level change
Also identifies the current run level
Identifies the number of times the system has been at this
run level since the last reboot
Identifies the previous run level
