 Task  |
 Description  |
 For Instructions  |
 Use the Boot PROM  |
 The boot PROM is used to boot a system. You might need to do one of the following:  |
 Identify the PROM revision number.  | |
 Identify devices on the system to boot from.  | |
 Change the default boot device when a new disk is added or when you need to change the system boot method.  | |
 Boot the system  |
 Select one of the following boot methods:  |
 Boot to run level 3 - Used after shutting down the system or performing some system hardware maintenance task.  |
 SPARC: How to Boot a System to Run Level 3 (Multiuser Level)  |
 Boot to run level S - Used after performing some system maintenance task such as backing up a file system. At this level, only local file systems are mounted and users cannot log into the system.  |
 SPARC: How to Boot a System to Run Level S (Single-User Level)  |
 Boot interactively - Used after making temporary changes to a system file or the kernel for testing purposes.  | |
 Boot from the network - Used to boot a system from the network. This method is used for booting a diskless client.  | |
 Boot for recovery purposes - Used to boot the system when a damaged file or file system is preventing the system from booting. You might need to do one or both of the following to boot for recovery purposes:  |
 First, stop the system to attempt recovery.  | |
 Boot to repair an important system file that is preventing the system from booting successfully.  | |
 Boot kadb - Used to troubleshoot system problems.  | |
 Force a crash dump and reboot the system - Used to force a crash dump for troubleshooting purposes.  |
