The following example shows how to identify the devices connected to an Ultra10 system.
ok setenv auto-boot? false
auto-boot? = false
ok reset-all
Resetting ...
Sun Ultra 5/10 UPA/PCI (UltraSPARC-IIi 333MHz), No Keyboard
OpenBoot 3.15, 128 MB memory installed, Serial #10933339.
Ethernet address 8:0:20:a6:d4:5b, Host ID: 80a6d45b.
ok probe-ide
Device 0 ( Primary Master )
ATA Model: ST34321A
Device 1 ( Primary Slave )
Not Present
Device 2 ( Secondary Master )
Removable ATAPI Model: CRD-8322B
Device 3 ( Secondary Slave )
Not Present
ok setenv auto-boot? true
auto-boot? = true
You can use the devalias command to identify the device aliases and the associated paths of devices that might be connected to the system.
ok devalias screen /pci@1f,0/pci@1,1/SUNW,m64B@2 net /pci@1f,0/pci@1,1/network@1,1 cdrom /pci@1f,0/pci@1,1/ide@3/cdrom@2,0:f disk /pci@1f,0/pci@1,1/ide@3/disk@0,0 disk3 /pci@1f,0/pci@1,1/ide@3/disk@3,0 disk2 /pci@1f,0/pci@1,1/ide@3/disk@2,0 disk1 /pci@1f,0/pci@1,1/ide@3/disk@1,0 disk0 /pci@1f,0/pci@1,1/ide@3/disk@0,0 ide /pci@1f,0/pci@1,1/ide@3 floppy /pci@1f,0/pci@1,1/ebus@1/fdthree ttyb /pci@1f,0/pci@1,1/ebus@1/se:b ttya /pci@1f,0/pci@1,1/ebus@1/se:a keyboard! /pci@1f,0/pci@1,1/ebus@1/su@14,3083f8:forcemode keyboard /pci@1f,0/pci@1,1/ebus@1/su@14,3083f8 mouse /pci@1f,0/pci@1,1/ebus@1/su@14,3062f8 name aliases |
