If a system is turned off, turning it on starts the multiuser boot sequence. The following procedures show how to boot to different run levels from the ok PROM prompt. These procedures assume that the system has been cleanly shut down, unless stated otherwise.
Use the who -r command to verify that the system is brought to the specified run level. For a description of run levels, see Chapter 8, Run Levels and Boot Files (Tasks).
Use this procedure to boot a system that is currently at run level 0 to run level 3.
Boot the system to run level 3.
ok boot |
The automatic boot procedure displays a series of startup messages, and brings the system to run level 3.
For more information, see boot(1M).
Verify that the system has booted to run level 3.
The login prompt is displayed when the boot process has finished successfully.
hostname console login: |
The following example displays the messages from booting a system to run level 3.
ok boot Sun Ultra 5/10 UPA/PCI (UltraSPARC-IIi 333MHz) OpenBoot 3.15, 128 MB memory installed, Serial #number. Ethernet address number, Host ID: number. Rebooting with command: boot Boot device: disk:a File and args: SunOS Release 5.9 Version Generic 64-bit Copyright (c) 1983-2002 by Sun Microsystems, Inc. configuring IPv4 interfaces: hme0. Hostname: starbug The system is coming up. Please wait. checking ufs filesystems /dev/rdsk/c0t0d0s7: is clean. /dev/rdsk/c0t0d0s4: is clean. NIS domainname is Solar.COM starting rpc services: rpcbind keyserv ypbind done. Setting netmask of hme0 to 255.255.255.0 Setting default IPv4 interface for multicast: add net 224.0/4: gateway starbug syslog service starting. Print services started. volume management starting. The system is ready. starbug console login: |
Use this procedure to boot a system that is currently at run level 0 to run level S.
Boot the system to run level S.
ok boot -s |
Type the superuser password when the following message is displayed.
INIT: SINGLE USER MODE Type Ctrl-d to proceed with normal startup, (or give root password for system maintenance): xxx |
Verify that the system is at run level S.
# who -r . run-level S Jun 10 15:27 3 0 |
To bring the system up to multiuser state after you completed the system maintenance task, press Control-D.
The following example displays the messages from booting a system to run level S.
ok boot -s . . . Sun Microsystems Inc. SunOS 5.9 Generic May 2002 Copyright 1983-2003 Sun Microsystems, Inc. All rights reserved. Use is subject to license terms. configuring IPv4 interfaces: hme0. Hostname: starbug INIT: SINGLE USER MODE Type control-d to proceed with normal startup, (or give root password for system maintenance): xxx Sun Microsystems Inc. SunOS 5.9 Generic May 2002 # who -r . run-level S Sep 19 08:49 S 0 ? (Perform some maintenance task) # Press Control-D |
Use this procedure to boot a system and you need to specify an alternate kernel or /etc/system file.
Boot the system interactively.
ok boot -a |
Answer the system prompts as described in the following table.
System Prompt |
Action |
Enter filename [kernel/[sparcv9]/unix]: |
Provide the name of kernel to use for booting. Or, press Return to use the default kernel. |
Enter default directory for modules [/platform/`uname -i`/kernel /platform/`uname -m/kernel /kernel /usr/kernel]: |
Provide an alternate path for the modules directory. Or, press Return to use the default kernel modules directory. |
Name of system file [etc/system]: |
Provide the name of an alternate system file and press Return. Type /dev/null if your /etc/system file has been damaged. Or, press Return to use the default etc/system file. |
root filesystem type [ufs]: |
Press Return to use the default root (/) file system. Type UFS for local disk booting, or NFS for network booting. |
Enter physical name of root device [physical_device_name]: |
Provide an alternate device name and press Return. Or, press Return to use the default physical name of the root device. |
If you are not prompted to answer the questions in the preceding table, verify that you typed the boot -a command correctly.
In the following example, the default choices (shown in square brackets []) are accepted.
ok boot -a . . . Rebooting with command: boot -a Boot device: /pci@1f,0/pci@1,1/ide@3/disk@0,0:a File and args: -a Enter filename [kernel/sparcv9/unix]: Press Return Enter default directory for modules [/platform/SUNW,Ultra-5_10/kernel /platform/sun4u/kernel /kernel /usr/kernel]: Press Return Name of system file [etc/system]: Press Return SunOS Release 5.9 Version Generic 64-bit Copyright (c) 1983-2002 by Sun Microsystems, Inc. root filesystem type [ufs]: Press Return Enter physical name of root device [/pci@1f,0/pci@1,1/ide@3/disk@0,0:a]: Press Return configuring IPv4 interfaces: hme0. Hostname: starbug The system is coming up. Please wait. checking ufs filesystems . . . The system is ready. starbug console login: |
Any system can boot from the network if there is a boot server available. You might want to boot a standalone system from the network temporarily if the system cannot boot from the local disk. For information on changing or resetting the default boot device, see SPARC: How to Change the Default Boot Device.
Two network configuration boot strategies are available on sun4u systems:
RARP (Reverse Address Resolution Protocol and ONC+ RPC Bootparams Protocol)
DHCP (Dynamic Host Configuration Protocol)
The default network boot strategy is set to RARP. You can use either strategy depending on whether a RARP boot server or a DHCP boot server is available on your network.
Sun Ultra systems must have PROM version 3.25.nn or later to use the DHCP network boot strategy. For information on finding your PROM version, see SPARC: How to Find the PROM Revision for a System.
If both methods are available, you can specify which service to use in the boot command temporarily. Or, you can save the network boot strategy across system reboots at the PROM level, by setting up an NVRAM alias. The following example uses the nvalias command to set up a network device alias for booting DHCP by default on a Sun Ultra 10 system.
ok nvalias net /pci@1f,4000/network@1,1:dhcp |
This alias means that when you type boot net, the system boots by using the DHCP network book strategy.
You should not use the nvalias command to modify the NVRAMRC file unless you are very familiar with the syntax of this command and the nvunalias command. For information on using these commands, see the OpenBoot 3.x Command Reference Manual.
If necessary, shut down the system.
Determine the method for booting from the network and select one of the following:
You must have already set up a RARP or DHCP boot server in your network to use either method to boot successfully.
Boot the system from the network by using the DHCP method.
ok boot net[:dhcp] |
If you have changed the PROM setting to boot DHCP by default, as in the preceding nvalias example, you only have to specify boot net.
Boot the system from the network by using the RARP method.
ok boot net[:rarp] |
Since RARP is the default network boot strategy, you only have to specify boot net:rarp if you have changed the PROM value to boot DHCP.
Type the stop key sequence for your system.
The monitor displays the ok PROM prompt.
ok |
The specific stop key sequence depends on your keyboard type. For example, you can press Stop-A or L1-A. On terminals, press the Break key.
Synchronize the file systems.
ok sync |
When you see the syncing file systems... message, press the stop key sequence for your system again.
Type the appropriate boot command to start the boot process.
Verify that the system is booted to the specified run level.
# who -r . run-level 3 May 2 07:39 3 0 S |
Press Stop-A ok sync syncing file systems... Press Stop-A ok boot |
Use this procedure when an important file, such as /etc/passwd, has an invalid entry and causes the boot process to fail.
Substitute the device name of the file system to be repaired for the devicename variable in the following procedures. If you need help identifying a system's device names, refer to “Accessing Devices (Overview)” in System Administration Guide: Devices and File Systems.
Stop the system by using the system's stop key sequence.
Use the stop sequence for your system if you don't know the root password or if you can't log in to the system. For more information, see SPARC: How to Stop the System for Recovery Purposes.
Follow the instructions in the table, depending on whether you are booting from the Solaris installation CD or DVD or from the network.
Boot Type |
Action |
Solaris installation CD or DVD |
1. Insert the Solaris installation media into the drive. 2. Boot from the installation media in single-user mode: ok boot cdrom -s |
The network if an installation server or remote CD or DVD drive are available |
Use the following command: ok boot net -s |
Mount the file system that contains the file with an invalid entry.
# mount /dev/dsk/device-name /a |
Change to the newly mounted file system.
# cd /a/file-system |
Set the terminal type.
# TERM=sun # export TERM |
Remove the invalid entry from the file by using an editor.
# vi filename |
Change to the root (/) directory.
# cd / |
Unmount the /a directory.
# umount /a |
Reboot the system.
# init 6 |
Verify that the system booted to run level 3.
The following example shows how to repair an important system file (in this case, /etc/passwd) after booting from a local CD-ROM.
ok boot cdrom -s # mount /dev/dsk/c0t3d0s0 /a # cd /a/etc # TERM=vt100 # export TERM # vi passwd (Remove invalid entry) # cd / # umount /a # init 6 |
The following example shows how to recover when you forget the root password by booting from the network. This example assumes that the network boot server is already available. Be sure to apply a new root password after the system has rebooted.
ok boot net -s # mount /dev/dsk/c0t3d0s0 /a # cd /a/etc # TERM=vt100 # export TERM # vi shadow (Remove root's encrypted password string) # cd / # umount /a # init 6 |
If you need to stop the system, type the stop key sequence for your system.
The PROM displays the ok prompt.
Synchronize the file systems and write the crash dump.
> n ok sync |
Boot the system with the kernel debugger.
ok boot kadb |
Check kadb boot messages to verify that the system has booted with the kernel debugger.
Rebooting with command: kadb Boot device: /iommu/sbus/espdma@4,800000/esp@4,8800000/sd@3,0 . . . |
Press Stop-A ok sync syncing file systems... Press Stop-A ok boot kadb |
