System Administration Guide: Basic Administration
x86: Configuration Assistant Screen
This screen appears each time you boot the Solaris Device Configuration Assistant. The Solaris Device Configuration Assistant runs every time the system is booted, although the autoboot process bypasses the menus.
The Solaris(TM) (Intel Platform Edition) Device Configuration Assistant
scans to identify system hardware, lists identified devices, and can
boot the Solaris software from a specified device. This program must be
used to install the Solaris operating environment, add a driver,
or change the hardware on the system.
> To perform a full scan to identify all system hardware, choose Continue.
> To diagnose possible full scan failures, choose Specific Scan.
> To add new or updated device drivers, choose Add Driver.
About navigation...
    - The mouse cannot be used.
    - If the keyboard does not have function keys or they do not respond,
      press ESC. The legend at the bottom of the screen will change to
      show the ESC keys to use for navigation.
    - The F2 key performs the default action.
F2_Continue		F3_Specific Scan		F4_Add Driver		F6_Help
