The following table describes the boot process on SPARC based systems.
Table 12–1 SPARC: Description of the Boot Process
Boot Phase |
Description |
Boot PROM |
1. The PROM displays system identification information and then runs self-test diagnostics to verify the system's hardware and memory. |
2. Then, the PROM loads the primary boot program, bootblk, whose purpose is to load the secondary boot program (that is located in the ufs file system) from the default boot device. |
Boot Programs |
3. The bootblk program finds and executes the secondary boot program, ufsboot, and loads it into memory. |
4. After the ufsboot program is loaded, the ufsboot program loads the kernel. |
Kernel Initialization |
5. The kernel initializes itself and begins loading modules by using ufsboot to read the files. When the kernel has loaded enough modules to mount the root (/) file system, the kernel unmaps the ufsboot program and continues, using its own resources. |
6. The kernel creates a user process and starts the /sbin/init process, which starts other processes by reading the /etc/inittab file. |
init |
7. The /sbin/init process starts the run control (rc) scripts, which execute a series of other scripts. These scripts (/sbin/rc*) check and mount file systems, start various processes, and perform system maintenance tasks. |
