System Administration Guide: Basic Administration
Shutting Down the System
Solaris software is designed to run continuously so that the electronic mail and network software can work correctly. However, some system administration tasks and emergency situations require that the system is shut down to a level where it is safe to remove power. In some cases, the system needs to be brought to an intermediate level, where not all system services are available, such as the following:
For a complete list of system administration tasks that require a system shutdown, see Chapter 7, Shutting Down and Booting a System (Overview).
For information on using your system's power management features, see Solaris Common Desktop Environment: User's Guide.
System Shutdown Commands
The use of the init and shutdown commands are the primary ways to shut down a system. Both commands perform a clean shutdown of the system, which means that all file system changes are written to the disk, and all system services, processes, and the operating system are terminated normally.
The use of a system's stop key sequence or turning a system off and then on are not clean shutdowns because system services are terminated abruptly. However, it is sometimes necessary to use these actions in emergency situations. For instructions on system recovery techniques, see Chapter 10, SPARC: Booting a System (Tasks) or Chapter 11, x86: Booting a System (Tasks).
The following table describes the various shutdown commands and provides recommendations for using them.
Table 9–1 Shutdown Commands
Command
Description
When To Use
shutdown
An executable shell script that calls the init program to shut down the system. The system is brought to run level S by default.
Recommended for servers running at run level 3 because users are notified of the impending shut down. Also notified are the systems that are mounting resources from the server that is being shut down.
init
An executable that kills all active processes and syncs the disks before changing run levels.
Recommended for standalone systems when other users will not be affected. Provides a faster system shutdown because users are not notified of the impending shutdown.
reboot
An executable that syncs the disks and passes boot instructions to the uadmin system call, which, in turn, stops the processor.
Not recommended. Use the init command instead.
halt
An executable that syncs the disks and stops the processor.
Not recommended because it doesn't execute the /etc/rc0 script. This script stops all processes, syncs the disks, and unmounts any remaining file systems.
User Notification of System Down Time
When the shutdown command is initiated, a warning followed by a final shutdown message is broadcast to all users who are currently logged onto the system and all systems that are mounting resources from the affected system.
For this reason, the shutdown command is recommended over the init command when you need to shut down a server. When you use either command, you might want to give users more notice by sending them a mail message about any scheduled system shutdown.
Use the who(1) command to determine which users on the system need to be notified. This command is also useful for determining a system's current run level. See How to Determine a System's Run Level.
How to Determine Who Is Logged in to a System
  1. Log into the system to be shut down.
  2. Display logged-in users.
    $ who
Example—Determining Who Is Logged in to a System
The following example shows how to display who is logged in to the system.
$ who
holly 1     console      May  7 07:30
kryten      pts/0  2     May  7 07:35	  (starbug) 4
lister      pts/1        May  7 07:40 3 (bluemidget)
  1. Identifies the user name of the logged-in user.
  2. Identifies the terminal line of the logged-in user.
  3. Identifies the date and time that the user logged in.
  4. (Optional) Identifies the host name if a user is logged in from a remote system.
How to Shut Down a Server
Use this procedure when you need to shut down a server.
  1. Become superuser.
  2. Find out if users are logged in to the system.
    # who
    A list of all logged-in users is displayed. You might want to send mail or broadcast a message to let users know that the system is being shut down.
  3. Shut down the system.
    # shutdown -iinit-level -ggrace-period -y
    -iinit-level
    Brings the system to an init level that is different from the default of S. The choices are 0, 1, 2, 5, and 6.
    -ggrace-period
    Indicates a time (in seconds) before the system is shut down. The default is 60 seconds.
    -y
    Continues to shut down the system without intervention. Otherwise, you are prompted to continue the shutdown process after 60 seconds.
    For more information, see shutdown(1M).
  4. If you are asked for confirmation, type y.
    Do you want to continue? (y or n): y
    If you used the shutdown -y command, you will not be prompted to continue.
  5. Type the superuser password, if prompted.
    Type Ctrl-d to proceed with normal startup,
    (or give root password for system maintenance): xxx
  6. After you have finished the system administration tasks, press Control-D to return to the default system run level.
  7. Use the following table to verify that the system is at the run level that you specified in the shutdown command.
    Specified Run Level
    SPARC System Prompt
    x86 System Prompt
    S (single-user level)
    0 (power-down level)
    ok or >
    type any key to continue
    Run level 3 (multiuser level with remote resources shared)
    hostname console login:
SPARC: Example—Bringing a Server to Run Level S
In the following example, the shutdown is used to bring a SPARC based system to run level S (single-user level) in 3 minutes.
# who
root       console      Dec 13 14:30
# shutdown -g180 -y
Shutdown started.    Thu Dec 13 14:30:32 MST 2001
Broadcast Message from root (console) on earth Thu Dec 13 14:30:33...
The system earth will be shut down in 3 minutes
The system earth will be shut down in 30 seconds
INIT: New run level: S
The system is coming down for administration.  Please wait.
Unmounting remote filesystems: /vol nfs done.
Shutting down Solaris Management Console server on port 898.
Print services stopped.
Dec 13 14:34:00 earth syslogd: going down on signal 15
Killing user processes: done.
INIT: SINGLE USER MODE
Type control-d to proceed with normal startup,
Entering System Maintenance Mode ...
SPARC: Example—Bringing a Server to Run Level 0
In the following example, the shutdown command is used to bring a SPARC based system to run level 0 in 5 minutes without requiring additional confirmation.
# who
root       console      Dec 12 08:08
rimmer     pts/0        Dec 11 14:48    (starbug)
pmorph     pts/1        Dec 13 12:31    (bluemidget)
# shutdown -i0 -g300 -y
Shutdown started.    Thu Dec 13 14:51:39 MST 2001
Broadcast Message from root (console) on earth Thu Dec 13 14:51:39...
The system earth will be shut down in 5 minutes
Changing to init state 0 - please wait
INIT: New run level: 0
The system is coming down.  Please wait.
System services are now being stopped.
The system is down.
syncing file systems... done
Program terminated
Type  help  for more information
ok
If you are bringing the system to run level 0 to turn off power to all devices, see How to Turn Off Power to All Devices.
SPARC: Example—Rebooting a Server to Run Level 3
In the following example, the shutdown command is used to reboot a SPARC based system to run level 3 in two minutes without requiring additional confirmation.
# who
# shutdown -i6 -g120 -y
Shutdown started.    Thu Dec 13 15:56:30
Broadcast Message from root (console) on earth Thu Dec 13 15:56:30...
The system earth will be shut down in 2 minutes
Changing to init state 6 - please wait
INIT: New run level: 6
The system is down.
rebooting...
earth console login:
Where to Go From Here
Regardless of why you shut down a system, you'll probably want to return to run level 3 where all file resources are available and users can log in. For instructions on bringing a system back to a multiuser level, see Chapter 10, SPARC: Booting a System (Tasks) or Chapter 11, x86: Booting a System (Tasks).
How to Shut Down a Standalone System
Use this procedure when you need to shut down a standalone system.
  2. Shut down the system.
    # init run-level
    run-level identifies the new run level.
    For more information, see init(1M).
  3. Use the following table to verify that the system is at the run level that you specified in the init command.
    Specified Run Level
    SPARC System Prompt
    x86 System Prompt
    2 (multiuser level)
    ok or >type any key to continue
    3 (multiuser level with NFS resources shared)
x86: Example—Bringing a Standalone System to Run Level 0
In the following example, the init command is used to bring an x86 based standalone system to the level where it is safe to turn off power.
# init 0
The system is down.
syncing file systems... [11] [10] [3] done
Type any key to continue
SPARC: Example—Bringing a Standalone System to Run Level S
In the following example, the init is used to bring a SPARC based standalone system to run level S (single-user level).
# init s
Regardless of why you shut down the system, you'll probably want to return to run level 3 where all file resources are available and users can log in. For instructions on bringing a system back to a multiuser level, see Chapter 10, SPARC: Booting a System (Tasks) or Chapter 11, x86: Booting a System (Tasks).
