These tools are new or changed in the Solaris 9 release:
Diskless client support
Solaris DHCP
Resource Management
Solaris Management Console (referred to as the console) tools suite
Solaris Volume Manager (previously SolsticeTM DiskSuite)
Solaris Patch Manager
Product Registry
The following table provides a brief description of each tool and where to find more information about them.
Table 1–1 New or Changed Solaris Management Tools in the Solaris 9 Release|
Solaris Administration Tool |
Description |
For More Information |
Diskless Client Support |
Provides a command-line interface for managing diskless client systems. | |
Resource Management |
Enables you to control how applications use available system resources. |
System Administration Guide: Resource Management and Network Services |
Solaris DHCP |
Provides improved performance, capacity, and flexibility in managing DHCP in your network. |
“About Solaris DHCP (Overview)” in System Administration Guide: IP Services |
Solaris Management Console 1 |
Serves as a launching point for a variety of GUI-based system management tools. |
This guide and the console online help |
Solaris Volume Manager (previously SolsticeTM DiskSuite) |
Provides robust storage management and is launched from the Solaris Management Console. The command-line interface is also available. | |
Solaris Patch Manager |
You can use this tool to add signed and unsigned patches to your system. | |
Solaris Product Registry |
The prodreg command includes browse, info, unregister, and uninstall subcommands that are similar to the Solaris Product Registry graphical user interface. |
Managing Software With the Solaris Product Registry Command-Line Interface (Task Map) |
1 Do not confuse this tool with Sun Management Center (SunMC). For information about the Sun Management Center product, see http://www.sun.com/solaris/sunmanagementcenter/docs.
