System Administration Guide: Basic Administration
Adding an Unsigned Solaris Patch
You can use the following tools to add unsigned patches to servers or standalone systems:
If you need to add a patch to a diskless client system, see Patching Diskless Client OS Services.
When you add a patch, the patch tools call the pkgadd command to install the patch packages from the patch directory to a local system's disk. More specifically, the patch tools do the following:
During patch installation, the patchadd command keeps a log of the patch installation in the /var/sadm/patch/patch-ID/log file for current Solaris versions.
The patchadd command will not install a patch under the following conditions:
When you add or remove patches with the smpatch command, the command prompts you for authentication information if you do not specify the information in the command line.
You can specify authentication information to the smpatch command using the following syntax:
# smpatch add -p mypassword -u root -- -i patch-ID-revision
The smpatch subcommands, such as add or remove, are separated from the authentication options and arguments by --.
Or, you can let the smpatch command prompt you for the authentication information.
# /usr/sadm/bin/smpatch add -i patch-ID-revision
Type /? for help, pressing <enter> accepts the default denoted by [ ]
Please enter a string value for: password ::
Loading Tool: com.sun.admin.patchmgr.cli.PatchMgrCli from holoship
Login to holoship as user root was successful.
Download of com.sun.admin.patchmgr.cli.PatchMgrCli from holoship was
successful.
