Use this procedure on a system that runs the Solaris 9 release.
This procedure assumes that the patch is has already been downloaded to the /var/sadm/spool directory and is unzipped.
Become superuser.
Add the patch or patches.
# /usr/sadm/bin/smpatch add patch-ID-revision |
# /usr/sadm/bin/smpatch add -i 115028-01
Authenticating as user: root
Type /? for help, pressing <enter> accepts the default denoted by [ ]
Please enter a string value for: password ::
Loading Tool: com.sun.admin.patchmgr.cli.PatchMgrCli from holoship
Login to holoship as user root was successful.
Download of com.sun.admin.patchmgr.cli.PatchMgrCli from holoship was
successful.
Patch 115028-01, or a patch required by patch 115028-01, requires a
system reboot after installation. Perform a reconfiguration reboot
immediately after the installation.
On machine holoship ...
Installing patch 115028-01
Check smpatch messages for instructions to reboot the system.
Reboot the system if you are instructed to reboot.
# init 6 |
Verify that the patch was added successfully.
# patchadd -p | grep patch-ID-revision |
