System Administration Guide: Basic Administration
How to Add a Signed Package (pkgadd)
This procedure assumes that you have imported Sun's Root CA certificate. For more information, see How to Import a Trusted Certificate into the Package Keystore (pkgadm addcert).
For information about setting up a proxy server, see How to Set Up a Proxy Server (pkgadd).
  1. Become superuser or assume an equivalent role.
  2. Add a signed package.
    # pkgadd -d /pathname/package-name
    The -d device-name option specifies the device from which the package is installed. The device can be a directory, tape, diskette, or removable disk. The device can also be a data stream created by the pkgtrans command.
Examples—Adding a Signed Package (pkgadd)
The following example shows how to add a signed package that has already been downloaded.
# # pkgadd -d /tmp/signed_pppd
The following packages are available:
  1  SUNWpppd     Solaris PPP Device Drivers
                  (sparc) 11.10.0,REV=2003.05.08.12.24
Select package(s) you wish to process (or 'all' to process
all packages). (default: all) [?,??,q]: all
Enter keystore password:
## Verifying signature for signer <User Cert 0>
The following example shows how to install a signed package using an HTTP URL as the device name. The URL must point to a stream-formatted package.
# pkgadd -d http://install/signed-video.pkg
## Downloading...
..............25%..............50%..............75%..............100%
## Download Complete
