System Administration Guide: Basic Administration
Example—Uninstalling Damaged Software (prodreg)
The following example shows how to uninstall the damaged ExampleSoft software. In this example, the uninstaller program is not readily available on a system backup.
# prodreg browse -m Examplesoft
BROWSE #  +/-/.  UUID                                  #  NAME
1         -      root                                  1  System
                                                          Registry
2          +     a01ee8dd-1dd1-11b2-a3f2-0800209a5b6b  1   Solaris 9 8/03
                                                          System
                                                          Software
3          +     8f64eabf-1dd2-11b2-a3f1-0800209a5b6b  1  Unclassified
                                                          Software
4          -     95842091-725a-8501-ef29-0472985982be  1  ExampleSoft
233         .    90209809-9785-b89e-c821-0472985982be  1  Example Doc
234         .    EXSOzzt                               1
235         .    EXSOblob                              1  Example Data
# prodreg uninstall -u 95842091-725a-8501-ef29-0472985982be -i 1
The install program requested could not be found
# prodreg info -m "ExampleSoft" -a uninstallprogram
uninstallprogram: /usr/bin/java -mx64m -classpath
/var/sadm/prod/org.example.ExampleSoft/987573587 uninstall_ExampleSoft
# ls /var/sadm/prod/org.example.ExampleSoft/987573587
/var/sadm/prod/org.example.ExampleSoft/987573587:
No such file or directory
# prodreg unregister -u 95842091-725a-8501-ef29-0472985982be -i 1
# pkgrm EXSOblob
