System Administration Guide: Basic Administration
Chapter 3 Managing User Accounts and Groups (Overview)
This chapter provides guidelines and planning information for managing user accounts and groups. This chapter also includes information about customizing the user's work environment.
This is a list of the overview information in this chapter.
For step-by-step instructions on managing user accounts and groups, see Chapter 4, Managing User Accounts and Groups (Tasks).
What's New in Managing Users and Groups?
This section describes new features for managing users and groups in the Solaris 9 release.
Solaris Management Console Tools Suite
The Solaris Management tools suite, available from the Solaris Management Console, enable you to manage all user and group features. For information on using the Solaris Management Console, see Chapter 2, Working With the SolarisTM Management Console (Tasks). For information on performing specific user and group management tasks, see What You Can Do With Solaris User Management Tools.
Solaris Directory Services
You can manage user and group information in a LDAP (Lightweight Directory Access Protocol) directory service with the iPlanetTM Directory Server, as well as other LDAP directory servers. Managing user and group information is also available in the NIS, NIS+, or files environment.
For information on setting up LDAP, see System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP).
For information on managing users and groups with iPlanet Directory Server, see iPlanet Directory Server 5.1 Administrator's Guide at this http://docs.sun.com/db/doc/816-2670? location.
Managing Users and Resources With Projects
In the Solaris 9 release, users and groups can be members of a project, an identifier that indicates a workload component that can be used as the basis of system usage or resource allocation chargeback. Projects are part of the Solaris resource management feature that is used to manage system resources.
Users need to be a member of a project to successfully log in to a system running the Solaris 9 release. By default, users are a member of the group.staff project when the Solaris 9 release is installed and no other project information is configured.
User project information is stored in the /etc/project file, which can be stored on the local system (files), the NIS name service, or the LDAP directory service. You can use the Solaris Management Console to manage project information.
The /etc/project file must exist for users to log in successfully, but requires no administration if you are not using projects.
For more information on using or setting up projects, see “Projects and Tasks” in System Administration Guide: Resource Management and Network Services.
What Are User Accounts and Groups?
One basic system administration task is to set up a user account for each user at a site. A typical user account includes the information a user needs to log in and use a system, without having the system's root password. User account information has the following components:
Component
Description
User name
A name that a user uses to log in to a system. This name is also known as a login name.
Password
A secret combination of characters that a user must enter with a user name to gain access to a system.
User's home directory
A directory that is usually the user's current directory at login. The user's home directory typically contains most of the user's files.
User initialization files
Shell scripts that control how the user's working environment is set up when a user logs in to a system.
Also, when you set up a user account, you can add the user to predefined groups of users. A typical use of groups is to set up group permissions on a file and directory, which allows access only to users who are part of that group.
For example, you might have a directory containing confidential files that only a few users should be able to access. You could set up a group called topsecret that includes the users working on the topsecret project. And, you could set up the topsecret files with read permission for the topsecret group. That way, only the users in the topsecret group would be able to read the files.
A special type of user account, called a role, is used to give selected users special privileges. For more information, see “Role-Based Access Control (Overview)” in System Administration Guide: Security Services.
A user or group can be a member of one or more projects. A project is an identifier that is used to chargeback system resources. For information on using projects, see “Projects and Tasks” in System Administration Guide: Resource Management and Network Services.
Guidelines for Managing User Accounts
The following sections describe some guidelines and planning information for creating user accounts.
Name Services
If you are managing user accounts for a large site, you might want to consider using a name or directory service such as LDAP, NIS, or NIS+. A name or directory service enables you to store user account information in a centralized manner instead of storing user account information in every system's /etc files. When using a name or directory service for user accounts, users can move from system to system using the same user account without having site-wide user account information duplicated on every system. Using a name or directory service also promotes centralized and consistent user account information.
User (Login) Names
User names, also called login names, let users access their own systems and remote systems that have the appropriate access privileges. You must choose a user name for each user account you create.
Keep the following guidelines in mind when creating user or role names:
Even though user names can include a period (.), underscore (_), or hyphen (-), using these characters is not recommended because they can cause problems with some software products.
Consider establishing a standard way of assigning user names so they are easier for you to track. Also, names should be easy for users to remember. A simple scheme when selecting a user name is to use the first name initial and first seven letters of the user's last name. For example, Ziggy Ignatz becomes zignatz. If this scheme results in duplicate names, you can use the first initial, middle initial, and the first six characters of the user's last name. For example, Ziggy Top Ignatz becomes ztignatz. If this scheme still results in duplicate names, consider using the following scheme:
Note –
Each new user name must be distinct from any mail aliases known to the system or to an NIS or NIS+ domain. Otherwise, mail might be delivered to the alias rather than to the actual user.
User ID Numbers
Associated with each user name is a user identification (UID) number. The user UID identifies the user name to any system on which the user attempts to log in. And, the user UID is used by systems to identify the owners of files and directories. If you create user accounts for a single individual on a number of different systems, always use the same user name and user ID. In that way, the user can easily move files between systems without ownership problems.
UID numbers must be a whole number less than or equal to 2147483647. UID numbers are required for both regular user accounts and special system accounts. The following table lists the UID numbers reserved for user accounts and system accounts.
Table 3–1 Reserved UID Numbers
User ID Numbers
Use or Login Accounts
Description
0 - 99
root, daemon, bin, sys, and so on.
System accounts
100 - 2147483647
Regular users
General purpose accounts
60001 and 65534
nobody and nobody4
Anonymous users
60002
noaccess
Non-trusted users
Although UID numbers 0 through 99 are reserved, you can add a user with one of these numbers. However, do not use 0 through 99 for regular user accounts. By definition, root always has UID 0, daemon has UID 1, and pseudo-user bin has UID 2. In addition, you should give uucp logins and pseudo user logins, like who, tty, and ttytype, low UIDs so they fall at the beginning of the passwd file.
As with user (login) names, you should adopt a scheme to assign unique UIDs. Some companies assign unique employee numbers, and administrators add a number to the employee number to create a unique UID number for each employee.
To minimize security risks, you should avoid reusing the UIDs from deleted accounts. If you must reuse a UID, “wipe the slate clean” so the new user is not affected by attributes set for a former user. For example, a former user might have been denied access to a printer by being included in a printer deny list, but that attribute might not be appropriate for the new user.
Using Large User IDs and Group IDs
UIDs and GIDs can be assigned up to the maximum value of a signed integer, or 2147483647.
However, UIDs and GIDs over 60000 do not have full functionality and are incompatible with many Solaris features, so avoid using UIDs or GIDs over 60000.
The following table describes interoperability issues with Solaris products and previous Solaris releases.
Table 3–2 Interoperability Issues for UIDs or GIDs Over 60000
Category
Product or Command
Issues or Cautions
NFSTM Interoperability
SunOSTM 4.0 NFS software and compatible releases
NFS server and client code truncates large UIDs and GIDs to 16 bits. This situation can create security problems if systems running SunOS 4.0 and compatible releases are used in an environment where large UIDs and GIDs are being used. Systems running SunOS 4.0 and compatible releases require a patch to avoid this problem.
Name Service Interoperability
NIS name service and file-based name service
Users with UIDs greater than 60000 can log in or use the su command on systems running the Solaris 2.5 and compatible releases, but their UIDs and GIDs will be set to 60001 (nobody).
NIS+ name service
Users with UIDs greater than 60000 are denied access on systems running Solaris 2.5 and compatible releases and the NIS+ name service.
Table 3–3 Large UID or GID Limitation Summary
UID or GID
Limitations
60003 or greater
  • Users in this category logging into systems running Solaris 2.5 and compatible releases and the NIS or files name service get a UID and GID of nobody.
65535 or greater
  • Systems running Solaris 2.5 and compatible releases with the NFS version 2 software see UIDs in this category truncated to 16 bits, creating possible security problems.
  • Users in this category using the cpio command with the default archive format to copy a file see an error message for each file. And, the UIDs and GIDs are set to nobody in the archive.
  • SPARC based systems: Users in this category running SunOS 4.0 and compatible applications see EOVERFLOW returns from some system calls, and their UIDs and GIDs are mapped to nobody.
  • x86 based systems: Users in this category running SVR3-compatible applications will probably see EOVERFLOW return codes from system calls.
  • x86 based systems: If users in this category attempt to create a file or directory on a mounted System V file system, the System V file system returns an EOVERFLOW error.
100000 or greater
  • The ps -l command displays a maximum five-digit UID so the printed column won't be aligned when they include a UID or GID larger than 99999.
262144 or greater
  • Users in this category using the cpio command with the -H odc format or the pax -x cpio command to copy files see an error message returned for each file. And, the UIDs and GIDs are set to nobody in the archive.
1000000 or greater
  • Users in this category using the ar command have their UIDs and GIDs set to nobody in the archive.
2097152 or greater
  • Users in this category using the tar command, the cpio -H ustar command, or the pax -x tar command have their UIDs and GIDs set to nobody.
Passwords
You can specify a password for a user when you add the user. Or, you can force the user to specify a password when the user first logs in. User passwords must comply with the following syntax:
Although user names are publicly known, passwords must be kept secret and known only to users. Each user account should be assigned a password, which is a combination of six to eight letters, numbers, or special characters.
To make your computer systems more secure, ask users to change their passwords periodically. For a high level of security, you should require users to change their passwords every six weeks. Once every three months is adequate for lower levels of security. System administration logins (such as root and sys) should be changed monthly, or whenever a person who knows the root password leaves the company or is reassigned.
Many breaches of computer security involve guessing a legitimate user's password. You should make sure that users avoid using proper nouns, names, login names, and other passwords that a person might guess just by knowing something about the user.
Good choices for passwords include the following:
Do not use these choices for passwords:
Password Aging
If you are using NIS+ or the /etc files to store user account information, you can set up password aging on a user's password. Starting in the Solaris 9 12/02 release, password aging is also supported in the LDAP directory service.
Password aging enables you to force users to change their passwords periodically or to prevent a user from changing a password before a specified interval. If you want to prevent an intruder from gaining undetected access to the system by using an old and inactive account, you can also set a password expiration date when the account becomes disabled. You can set password aging attributes with the passwd command or the Solaris Management Console's Users Tool.
Home Directories
The home directory is the portion of a file system allocated to a user for storing private files. The amount of space you allocate for a home directory depends on the kinds of files the user creates, large or small, and the number of files created.
A home directory can be located either on the user's local system or on a remote file server. In either case, by convention the home directory should be created as /export/home/username. For a large site, you should store home directories on a server. Use a separate file system for each /export/homen directory to facilitate backing up and restoring home directories. For example, /export/home1, /export/home2.
Regardless of where their home directory is located, users usually access their home directories through a mount point named /home/username. When AutoFS is used to mount home directories, you are not permitted to create any directories under the /home mount point on any system. The system recognizes the special status of /home when AutoFS is active. For more information about automounting home directories, see “Task Overview for Autofs Administration” in System Administration Guide: Resource Management and Network Services.
To use the home directory anywhere on the network, you should always refer to the home directory as $HOME, not as /export/home/username. The latter is machine-specific. In addition, any symbolic links created in a user's home directory should use relative paths (for example, ../../../x/y/x), so the links will be valid no matter where the home directory is mounted.
User's Work Environment
Besides having a home directory to create and store files, users need an environment that gives them access to the tools and resources they need to do their work. When a user logs in to a system, the user's work environment is determined by initialization files that are defined by the user's startup shell, such as the C, Korn, or Bourne shell.
A good strategy for managing the user's work environment is to provide customized user initialization files, such as .login, .cshrc, .profile, in the user's home directory. For detailed information about customizing user initialization files for users, see Customizing a User's Work Environment. After you create the customized user initialization files, you can add them to a user's home directory when you create a new user account.
A recommended one-time task is to set up skeleton directories on a server. You can use the same server where the user's home directories are stored. The skeleton directories enable you to store customized user initialization files for different types of users.
Note –
Do not use system initialization files, such as /etc/profile or /etc/.login, to manage a user's work environment, because they reside locally on systems and are not centrally administered. For example, if AutoFS is used to mount the user's home directory from any system on the network, you would have to modify the system initialization files on each system to ensure a consistent environment when a user moved from system to system.
Another way to customize user accounts is through role-based access control. See “Role-Based Access Control (Overview)” in System Administration Guide: Security Services for more information.
Guidelines for Managing Groups
A group is a collection of users who can share files and other system resources. For example, a set of users that are working on the same project could be formed into a group. A group is traditionally known as a UNIX group.
Each group must have a name, a group identification (GID) number, and a list of user names that belong to the group. A GID identifies the group internally to the system. The two types of groups that a user can belong to are:
Sometimes a user's secondary group is not important. For example, ownership of files reflect the primary group, not any secondary groups. Other applications, however, might rely on a user's secondary memberships. For example, a user has to be a member of the sysadmin group (group 14) to use the Admintool software, but it doesn't matter if group 14 is his or her current primary group.
The groups command lists the groups that a user belongs to. A user can have only one primary group at a time. However, a user can temporarily change the user's primary group, with the newgrp command, to any other group in which the user is a member.
When adding a user account, you must assign a primary group for a user or accept the default group, staff (group 10). The primary group should already exist. If the primary group does not exist, specify the group by a GID number. User names are not added to primary groups. If user names were, the list might become too long. Before you can assign users to a new secondary group, you must create the group and assign it a GID number.
Groups can be local to a system or can be managed through a name service. To simplify group administration, you should use a name service like NIS or a directory service like LDAP, which enables you to centrally manage group memberships.
Tools for Managing User Accounts and Groups
The following table lists the recommended tools for managing users and groups. These tools are all included in the Solaris Management Console suite of tools. For information about starting and using the Solaris Management Console, see Chapter 2, Working With the SolarisTM Management Console (Tasks).
Table 3–4 Tools for Managing Users and Groups
Solaris Management Tool
Is Used To
Task Information
Users
Manage users.
Solaris Management Console Online Help
User Templates
Create a set of attributes for a specific kind of user like students, engineers, or instructors.
Rights
Manage RBAC rights.
Administrative Roles
Manage RBAC administrative roles.
Groups
Manage group information.
Projects
Manage project information.
Mailing Lists
Manage mailing lists.
For information on the Solaris management commands that can be used to manage user accounts and groups if you are not using the Solaris Management Console, see Table 1–6. These commands provide the same functionality as the Solaris management tools, including authentication and name service support.
The Solaris user management tools enable you to manage user accounts on a local system or in a name service environment.
This table describes the tasks you can do with Users Tool's User Accounts feature.
Table 3–5 User Account Management Tasks
Task
Description
Background Information
Add a user
You can add a user to the local system or name service.
What Are User Accounts and Groups? and Guidelines for Managing User Accounts
Create a user Template
You can create a template of pre-defined user attributes for creating users of the same group, such a users, contractors, or engineers.
Same as above
Add a user with a user template
You can add a user with a template so that user attributes are pre-defined.
Same as above
Clone a user template
Clone a user template if you would like to use a similar set of pre-defined user attributes. Then, change only some of the attributes as needed.
Same as above
Set up user properties
You can set up user properties in advance of adding users such as whether a user template is used when adding a user and whether the home directory or mail box is deleted by default when removing a user.
Same as above
Add multiple users
You can add multiple users to the local system or name service by specifying a text file, typing each name, or automatically generating a series of user names.
Same as above
View or change user properties
You can view or change user properties like login shell, password, or password options.
Same as above
Assign rights to users
You can assign rights to users that will allow them to perform specific administration tasks.
Same as above
Remove a user
You can remove the user from the local system or the name service and optionally specify whether the user's home directory or mail is removed. The user is also removed from any groups or roles.
Same as above
Table 3–6 User Rights Management Tasks
Task
Description
Grant a right
You can grant a user a right to run a specific command or application that was previously only available to an administrator.
“RBAC Rights Profiles” in System Administration Guide: Security Services
View or change existing rights Properties
You can view or change existing rights.
Same as above
Add an authorization
You can add an authorization, which is a discrete right granted to a role or a user.
“RBAC Authorizations” in System Administration Guide: Security Services
View or change an authorization
You can view or change existing authorizations.
Same as above
Table 3–7 User Role Management Tasks
Task
Description
Add an administrative role
You can add a role that someone would use to perform a specific administrative task.
“RBAC Roles” in System Administration Guide: Security Services
Assign rights to an administrative role
You can assign specific rights to a role that enable someone to perform a task.
Same as above
Change an administrative role
You can add or remove rights from a role.
Same as above
Table 3–8 Group Management Tasks
Task
Description
Add a group
Add a group to the local system or name service so that the group name is available before you add the user.
Add a user to a group
Add a user to a group if the user needs access to group-owned files.
Same as above
Remove a user from a group
You can remove a user from a group if the user no longer requires group file access.
Same as above
Table 3–9 Project Management Tasks
Task
Description
Create or clone a project
You can create a new project or clone an existing project if it has attributes similar to what you need for the new project.
Solaris Management Console online help
Modify or view project attributes
You can view or change existing project attributes.
Delete a project
You can remove a project if it is no longer used.
Table 3–10 Mailing List Management Tasks
Task
Description
Create a mailing list
You can create a mailing list, which is a list of names for sending email messages.
Change a mailing list name
You can make changes to the mailing list after it is created.
Remove a mailing list
You can remove a mailing list if it is no longer used.
Managing Home Directories With the Solaris Management Console
Keep the following in mind when using the Solaris Management Console tools to manage user home directories:
Modify User Accounts
Unless you define a user name or UID number that conflicts with an existing one, you should never need to modify a user account's login name or UID number. Use the following steps if two user accounts have duplicate user names or UID numbers:
If you do use the Users Tool to change a user name, the home directory's ownership is changed, if a home directory exists for the user.
One part of a user account that you can change is a user's group memberships. Select Properties from Users Tool's Action menu to add or delete a user's secondary groups. Alternatively, you can use the Groups Tool to directly modify a group's member list.
You can also modify the following parts of a user account:
Delete User Accounts
When you delete a user account with the Users Tool, the software deletes the entries in the passwd and group files. In addition, you can delete the files in the user's home directory and mail directory.
Add Customized User Initialization Files
Although you cannot create customized user initialization files with the Users Tool, you can populate a user's home directory with user initialization files located in a specified “skeleton” directory. You can do this by creating a user template with the User Templates tool and specifying a skeleton directory from which to copy user initialization files.
You can customize the user initialization templates in the /etc/skel directory and then copy them to users' home directories.
Administer Passwords
You can use Users Tool for password administration, which includes the following capabilities:
Note –
Password aging is not supported by the NIS name service.
Disable User Accounts
Occasionally, you might need to temporarily or permanently disable a login account. Disabling or locking a user account means that an invalid password, *LK*, is assigned to the user account, preventing future logins.
The easiest way to disable a user account is to lock the password for an account with Users Tool.
You can also enter an expiration date in the account availability section of the User Properties screen to set a limit on how long the account is active.
Other ways to disable a user account is to set up password aging or to change the user's password.
Where User Account and Group Information Is Stored
Depending on your site policy, you can store user account and group information in a name service or a local system's /etc files. In the NIS+ name service, information is stored in tables, in the NIS name service, information is stored in maps, and in the LDAP directory service, information is stored in indexed database files.
Note –
To avoid confusion, the location of the user account and group information is generically referred to as a file rather than as a database, table or map.
Most of the user account information is stored in the passwd file. However, password encryption and password aging is stored in the passwd file when using NIS or NIS+ and in the /etc/shadow file when using /etc files. Password aging is not available when using NIS.
Group information is stored in the group file.
Fields in the passwd File
The fields in the passwd file are separated by colons and contain the following information:
username:password:uid:gid:comment:home-directory:login-shell
For example:
kryten:x:101:100:Kryten Series 4000 Mechanoid:/export/home/kryten:/bin/csh
The following table describes the passwd file fields.
Table 3–11 Fields in the passwd File
Field Name
Description
username
Contains the user or login name. User names should be unique and consist of 1-8 letters (A-Z, a-z) and numerals (0-9). The first character must be a letter, and at least one character must be a lowercase letter.
password
Contains an x, a placeholder for the encrypted password. The encrypted password is stored in the shadow file.
uid
Contains a user identification (UID) number that identifies the user to the system. UID numbers for regular users should range from 100 to 60000. All UID numbers should be unique.
gid
Contains a group identification (GID) number that identifies the user's primary group. Each GID number must be a whole number between 0 and 60002. 60001 and 60002 are assigned to nobody and noaccess. 65534 is assigned to nobody4.
comment
Usually contains the full name of the user. This field is informational only. It is sometimes called the GECOS field because it was originally used to hold the login information needed to submit batch jobs to a mainframe running GECOS (General Electric Computer Operating System) from UNIX systems at Bell Labs.
home-directory
Contains the user's home directory path name.
login-shell
Contains the user's default login shell, such as /bin/sh, /bin/csh or /bin/ksh. Table 3–18 contains a description of shell features.
Default passwd File
The default Solaris passwd file contains entries for standard daemons, processes usually started at boot time to perform some system-wide task, such as printing, network administration, and port monitoring.
root:x:0:1:Super-User:/:/sbin/sh
daemon:x:1:1::/:
bin:x:2:2::/usr/bin:
sys:x:3:3::/:
adm:x:4:4:Admin:/var/adm:
lp:x:71:8:Line Printer Admin:/usr/spool/lp:
uucp:x:5:5:uucp Admin:/usr/lib/uucp:
nuucp:x:9:9:uucp Admin:/var/spool/uucppublic:/usr/lib/uucp/uucico
smmsp:x:25:25:SendMail Message Submission Program:/:
listen:x:37:4:Network Admin:/usr/net/nls:
nobody:x:60001:60001:Nobody:/:
noaccess:x:60002:60002:No Access User:/:
nobody4:x:65534:65534:SunOS 4.x Nobody:/:
Table 3–12 Default passwd File Entries
User Name
User ID
Description
root
0
Superuser account.
daemon
1
Umbrella system daemon associated with routine system tasks.
bin
2
Administrative daemon associated with running system binaries to perform some routine system task.
sys
3
Administrative daemon associated with system logging or updating files in temporary directories.
adm
4
Administrative daemon associated with system logging.
lp
71
Line printer daemon.
uucp
5
Daemon associated with uucp functions.
nuucp
6
smmsp
25
Sendmail message submission program daemon.
listen
37
Network listener daemon.
nobody
60001
Assigned to users or software processes that do not need nor should have any special permissions.
noaccess
60002
Assigned to a user or a process that needs access to a system through some application but without actually logging in.
nobody4
65534
SunOS 4.0 or 4.1 version of the nobody user account.
Fields in the shadow File
The fields in the shadow file are separated by colons and contain the following information:
username:password:lastchg:min:max:warn:inactive:expire
For example:
rimmer:86Kg/MNT/dGu.:8882:0::5:20:8978
The following table describes the shadow file fields.
Table 3–13 Fields in the shadow File
Field Name
Description
username
password
Might contain the following entries: a 13-character encrypted user password; the string *LK*, which indicates an inaccessible account; or the string NP, which indicates no password for the account.
lastchg
Indicates the number of days between January 1, 1970, and the last password modification date.
min
Contains the minimum number of days required between password changes.
max
Contains the maximum number of days the password is valid before the user is prompted to specify a new password.
inactive
Contains the number of days a user account can be inactive before being locked.
expire
Contains the absolute date when the user account expires. Past this date, the user cannot log in to the system.
Fields in the group File
The fields in the group file are separated by colons and contain the following information:
group-name:group-password:gid:user-list
For example:
bin::2:root,bin,daemon
The following table describes the group file fields.
Table 3–14 Fields in the group File
Field Name
Description
group-name
Contains the name assigned to the group. For example, members of the chemistry department in a university might be called chem. Group names can have a maximum of eight characters.
group-password
Usually contains an asterisk or is empty. The group-password field is a relic of earlier versions of UNIX. If a group has a password, the newgrp command prompts users to enter the password. However, no utility exists to set the password.
gid
Contains the group's GID number. It must be unique on the local system, and should be unique across the entire organization. Each GID number must be a whole number between 0 and 60002. Numbers under 100 are reserved for system default group accounts. User defined groups can range from 100 to 60000. 60001 and 60002 are reserved and assigned to nobody and noaccess, respectively.
user-list
Contains a comma-separated list of user names, representing the user's secondary group memberships. Each user can belong to a maximum of 15 secondary groups.
Default group file
The default Solaris group file contains the following system groups that support some system-wide task, such as printing, network administration, and electronic mail. Many of these groups having corresponding entries in the passwd file.
root::0:root
other::1:
sys::3:root,bin,sys,adm
adm::4:root,adm,daemon
uucp::5:root,uucp
mail::6:root
tty::7:root,adm
lp::8:root,lp,adm
nuucp::9:root,nuucp
staff::10:
daemon::12:root,daemon
smmsp::25:smmsp
sysadmin::14:root
nobody::60001:
noaccess::60002:
nogroup::65534:
Table 3–15 Default group File Entries
Group Name
Group ID
Description
root
0
Superuser group.
other
1
Optional group.
bin
2
Administrative group associated with running system binaries.
sys
3
Administrative group associated with system logging or temporary directories.
adm
4
Administrative group associated with system logging.
uucp
5
Group associated with uucp functions.
mail
6
Electronic mail group.
tty
7
Group associated with tty devices.
lp
8
Line printer group.
nuucp
9
staff
10
General administrative group.
daemon
12
Group associated with routine system tasks.
sysadmin
14
Administrative group associated with Admintool and Solstice AdminSuite tools.
smmsp
25
nobody
60001
Group assigned to users or software processes that do not need nor should have any special permissions.
noaccess
60002
Group assigned to a user or a process that needs access to a system through some application but without actually logging in.
nogroup
65534
Group assigned to a user who not a member of a known group.
Part of setting up a user's home directory is providing user initialization files for the user's login shell. A user initialization file is a shell script that sets up a work environment for a user after the user logs in to a system. Basically, you can perform any task in a user initialization file that you can do in a shell script. However, its primary job is to define the characteristics of a user's work environment, such as a user's search path, environment variables, and windowing environment. Each login shell has its own user initialization file or files, which are listed in the following table.
Table 3–16 User Initialization Files for Bourne, C, and Korn Shells
Shell
Purpose
Bourne
$HOME/.profile
Defines user's environment at login
C
$HOME/.cshrc
Defines user's environment for all C shells and is invoked after login shell
$HOME/.login
Korn
$HOME/.profile
$HOME/$ENV
Defines user's environment at login in the file and is specified by the Korn shell's ENV environment variable
The Solaris environment provides default user initialization files for each shell in the /etc/skel directory on each system, as shown in the following table.
Table 3–17 Default User Initialization Files
Shell
Default File
C
/etc/skel/local.login
/etc/skel/local.cshrc
Bourne or Korn
/etc/skel/local.profile
You can use these files as a starting point and modify them to create a standard set of files that provide the work environment common to all users. Or, you can modify them to provide the working environment for different types of users. For step-by-step instructions on how to create sets of user initialization files for different types of users, see How to Customize User Initialization Files.
When you use the Users Tool to create a new user account and select the create home directory option, the following files are created, depending on which login shell is selected:
Shell
Files Created
C
The /etc/skel/local.cshrc and the /etc/skel/local.login files are copied into the user's home directory and are renamed .cshrc and .login.
Bourne and Korn
The /etc/skel/local.profile file is copied into the user's home directory and renamed .profile.
If you use the useradd command to add a new user account and specify the /etc/skel directory by using the -k and -m options, all three /etc/skel/local* and /etc/skel/.profile files are copied into the user's home directory. At this point, you will need to rename them to whatever is appropriate for the user's login shell.
Using Site Initialization Files
The user initialization files can be customized by both the administrator and the user. This important feature can be accomplished with centrally located and globally distributed user initialization files, called site initialization files. Site initialization files enable you to continually introduce new functionality to the user's work environment, while enabling the user to customize the user's initialization file.
When you reference a site initialization file in a user initialization file, all updates to the site initialization file are automatically reflected when the user logs in to the system or when a user starts a new shell. Site initialization files are designed for you to distribute site-wide changes to users' work environments that you did not anticipate when you added the users.
Any customization that can be done in a user initialization file can be done in a site initialization file. These files typically reside on a server, or set of servers, and appear as the first statement in a user initialization file. Also, each site initialization file must be the same type of shell script as the user initialization file that references it.
To reference a site initialization file in a C-shell user initialization file, place a line similar to the following at the beginning of the user initialization file:
source /net/machine-name/export/site-files/site-init-file
To reference a site initialization file in a Bourne- or Korn-shell user initialization file, place a line similar to the following at the beginning of the user initialization file:
. /net/machine-name/export/site-files/site-init-file
Avoid Local System References
You should not add specific references to the local system in the user's initialization file. You want the instructions in a user initialization file to be valid regardless of the system to which the user logs in. For example:
Shell Features
The following table lists basic shell features that each shell provides, which can help you determine what you can and can't do when creating user initialization files for each shell.
Table 3–18 Basic Features of Bourne, C, and Korn Shells
Feature
Bourne
C
Korn
Known as the standard shell in UNIX
Yes
No
No
Compatible syntax with Bourne shell
No
Yes
Job control
Yes
Yes
Yes
History list
No
Yes
Yes
Command-line editing
No
Yes
Yes
Aliases
No
Yes
Yes
Single-character abbreviation for login directory
No
Yes
Yes
Protection from overwriting (noclobber)
No
Yes
Yes
Setting to ignore Control-d (ignoreeof)
No
Yes
Yes
Enhanced cd
No
Yes
Yes
Initialization file separate from .profile
No
Yes
Yes
Logout file
No
Yes
No
Shell Environment
A shell maintains an environment that includes a set of variables defined by the login program, the system initialization file, and the user initialization files. In addition, some variables are defined by default. A shell can have two types of variables:
In the C shell, you use the lowercase names with the set command to set shell variables and use uppercase names with the setenv command to set environment variables. If you set a shell variable, the shell sets the corresponding environment variable and vice versa. For example, if you update the path shell variable with a new path, the shell also updates the PATH environment variable with the new path.
In the Bourne and Korn shells, you can use the uppercase variable name equal to some value to set both shell and environment variables. You also have to use the export command to activate the variables for any subsequently executed commands.
For all shells, you generally refer to shell and environment variables by their uppercase names.
In a user initialization file, you can customize a user's shell environment by changing the values of the predefined variables or by specifying additional variables. The following table shows how to set environment variables in a user initialization file.
Table 3–19 Setting Environment Variables in a User Initialization File
Set a User's Environment Variables for The Shell Type
Line to Add to the User Initialization File
C shell
setenv VARIABLE value
Example:
setenv MAIL /var/mail/ripley
Bourne or Korn shell
VARIABLE=value; export VARIABLE
Example:
MAIL=/var/mail/ripley;export MAIL
The following table describes environment and shell variables that you might want to customize in a user initialization file. For more information about variables that are used by the different shells, see sh(1), ksh(1), or csh(1).
Table 3–20 Shell and Environment Variable Descriptions
Variable
Description
CDPATH, or cdpath in the C shell
Sets a variable used by the cd command. If the target directory of the cd command is specified as a relative path name, the cd command first looks for the target directory in the current directory (“.”). If the target is not found, the path names listed in the CDPATH variable are searched consecutively until the target directory is found and the directory change is completed. If the target directory is not found, the current working directory is left unmodified. For example, the CDPATH variable is set to /home/jean, and two directories exist under /home/jean, bin and rje. If you are in the /home/jean/bin directory and type cd rje, you change directories to /home/jean/rje, even though you do not specify a full path.
history
Sets history for the C shell.
HOME, or home in the C shell
Sets the path to the user's home directory.
LANG
Sets the locale.
LOGNAME
Defines the name of the user currently logged in. The default value of LOGNAME is set automatically by the login program to the user name specified in the passwd file. You should only need to refer to, not reset, this variable.
LPDEST
Sets the user's default printer.
MAIL
Sets the path to the user's mailbox.
MANPATH
Sets the hierarchies of man pages available.
PATH, or path in the C shell
Specifies, in order, the directories that the shell searches to find the program to run when the user types a command. If the directory is not in the search path, users must type the complete path name of a command.
The default PATH is automatically defined and set as specified in .profile (Bourne or Korn shell) or .cshrc (C shell) as part of the login process.
The order of the search path is important. When identical commands exist in different locations, the first command found with that name is used. For example, suppose that PATH is defined in Bourne and Korn shell syntax as PATH=/bin:/usr/bin:/usr/sbin:$HOME/bin and a file named sample resides in both /usr/bin and /home/jean/bin. If the user types the command sample without specifying its full path name, the version found in /usr/bin is used.
prompt
Defines the shell prompt for the C shell.
PS1
Defines the shell prompt for the Bourne or Korn shell.
SHELL, or shell in the C shell
Sets the default shell used by make, vi, and other tools.
TERMINFO
Specifies the path name for an unsupported terminal that has been added to the terminfo file. Use the TERMINFO variable in /etc/profile or /etc/.login.
When the TERMINFO environment variable is set, the system first checks the TERMINFO path defined by the user. If it does not find a definition for a terminal in the TERMINFO directory defined by the user, it searches the default directory, /usr/share/lib/terminfo, for a definition. If the system does not find a definition in either location, the terminal is identified as “dumb.”
TERM, or term in the C shell
Defines the terminal. This variable should be reset in /etc/profile or /etc/.login. When the user invokes an editor, the system looks for a file with the same name as the definition of this environment variable. The system searches the directory referenced by TERMINFO to determine the terminal characteristics.
TZ
Sets the time zone, which is used to display dates, for example, in the ls -l command. If TZ is not set in the user's environment, the system setting is used. Otherwise, Greenwich Mean Time is used.
The PATH Variable
When the user executes a command by using the full path, the shell uses that path to find the command. However, when users specify only a command name, the shell searches the directories for the command in the order specified by the PATH variable. If the command is found in one of the directories, the shell executes the command.
A default path is set by the system, but most users modify it to add other command directories. Many user problems related to setting up the environment and accessing the right version of a command or a tool can be traced to incorrectly defined paths.
Setting Path Guidelines
Here are some guidelines for setting up efficient PATH variables:
Examples—Setting a User's Default Path
The following examples show how to set a user's default path to include the home directory and other NFS mounted directories. The current working directory is specified first in the path. In a C-shell user initialization file, you would add the following:
set path=(. /usr/bin $HOME/bin /net/glrr/files1/bin)
In a Bourne- or Korn-shell user initialization file, you would add the following:
PATH=.:/usr/bin:/$HOME/bin:/net/glrr/files1/bin
export PATH
Locale Variables
The LANG and LC environment variables specify the locale-specific conversions and conventions for the shell, like time zones, collation orders, and formats of dates, time, currency, and numbers. In addition, you can use the stty command in a user initialization file to set whether the terminal session will support multibyte characters.
LANG sets all possible conversions and conventions for the given locale. If you have special needs, you can set various aspects of localization separately through these LC variables: LC_COLLATE, LC_CTYPE, LC_MESSAGES, LC_NUMERIC, LC_MONETARY, and LC_TIME.
The following table describes some of the values for the LANG and LC environment variables.
Table 3–21 Values for LANG and LC Variables
Value
Locale
de_DE.ISO8859-1
German
en_US.UTF-8
American English (UTF-8)
es_ES.ISO8859-1
Spanish
fr_FR.ISO8859-1
French
it_IT.ISO8859-1
Italian
ja_JP.eucJP
Japanese (EUC)
ko_KR.EUC
Korean (EUC)
sv_SE.ISO8859-1
Swedish
zh_CN.EUC
Simplified Chinese (EUC)
zh_TW.EUC
Traditional Chinese (EUC)
For more information on supported locales, see the International Language Environments Guide.
Examples—Setting the Locale Using the LANG Variables
The following examples show how to set the locale by using the LANG environment variables. In a C-shell user initialization file, you would add the following:
setenv LANG de_DE.ISO8859-1
LANG=de_DE.ISO8859-1; export LANG
Default File Permissions (umask)
When you create a file or directory, the default file permissions assigned to the file or directory are controlled by the user mask. The user mask is set by the umask command in a user initialization file. You can display the current value of the user mask by typing umask and pressing Return.
The user mask contains the following octal values:
Note that if the first digit is zero, it is not displayed. For example, if umask is set to 022, 22 is displayed.
To determine the umask value you want to set, subtract the value of the permissions you want from 666 (for a file) or 777 (for a directory). The remainder is the value to use with the umask command. For example, suppose you want to change the default mode for files to 644 (rw-r--r--). The difference between 666 and 644 is 022, which is the value you would use as an argument to the umask command.
You can also determine the umask value you want to set by using the following table, which shows the file and directory permissions that are created for each of the octal values of umask.
Table 3–22 Permissions for umask Values
umask Octal Value
File Permissions
Directory Permissions
0
rw-
rwx
1
rw-
rw-
2
r--
r-x
3
r--
r--
4
-w-
-wx
5
-w-
-w-
6
--x
--x
7
--- (none)
--- (none)
The following line in a user initialization file sets the default file permissions to rw-rw-rw-.
umask 000
Examples of User and Site Initialization Files
The following sections provide examples of user and site initialization files that you can use to start customizing your own initialization files. Many of the examples use system names and paths that you need to change for your particular site.
Example—.profile File
1 PATH=$PATH:$HOME/bin:/usr/local/bin:/usr/ccs/bin:.
2 MAIL=/var/mail/$LOGNAME
3 NNTPSERVER=server1
4 MANPATH=/usr/share/man:/usr/local/man
5 PRINTER=printer1
6 umask 022
7 export PATH MAIL NNTPSERVER MANPATH PRINTER
  1. Defines the user's shell search path.
  2. Defines the path to the user's mail file.
  3. Defines the user's Usenet news server.
  4. Defines the user's search path for man pages.
  5. Defines the user's default printer.
  6. Sets the user's default file creation permissions.
  7. Sets the listed environment variables.
Example—.cshrc File
1 set path=($PATH $HOME/bin /usr/local/bin /usr/ccs/bin)
2 setenv MAIL /var/mail/$LOGNAME
3 setenv NNTPSERVER server1
4 setenv PRINTER printer1
5 alias h history
6 umask 022
7 source /net/server2/site-init-files/site.login
  4. Defines the user's default printer.
  5. Creates an alias for the history command. The user will need to type only h to run the history command.
  7. Sources the site initialization file.
Example—Site Initialization File
The following shows an example site initialization file in which a user can choose a particular version of an application.
# @(#)site.login
main:
echo "Application Environment Selection"
echo ""
echo "1. Application, Version 1"
echo "2. Application, Version 2"
echo ""
echo -n "Type 1 or 2 and press Return to set your
application environment: "
set choice = $<
if ( $choice !~ [1-2] ) then
goto main
endif
switch ($choice)
case "1":
setenv APPHOME /opt/app-v.1
breaksw
case "2":
setenv APPHOME /opt/app-v.2
endsw
This site initialization file could be referenced in a user's .cshrc file (C shell users only) with the following line:
In this line, the site initialization file is named site.login and is located on a server named server2. This line also assumes that the automounter is running on the user's system.
