The ttymon port monitor is STREAMS-based and does the following:
Monitors ports
Sets terminal modes, baud rates, and line disciplines
Invokes the login process
The ttymon port monitor provides Solaris users the same services that getty did under previous versions of SunOS 4.1 software.
The ttymon port monitor runs under the SAC program and is configured with the sacadm command. Each instance of ttymon can monitor multiple ports. These ports are specified in the port monitor's administrative file. The administrative file is configured by using the pmadm and ttyadm commands.
