Though SAF provides a generic means for administering any future or third-party port monitors, only two are implemented in the Solaris environment: ttymon and listen.
The ttymon port monitor is STREAMS-based and does the following:
Monitors ports
Sets terminal modes, baud rates, and line disciplines
Invokes the login process
The ttymon port monitor provides Solaris users the same services that getty did under previous versions of SunOS 4.1 software.
The ttymon port monitor runs under the SAC program and is configured with the sacadm command. Each instance of ttymon can monitor multiple ports. These ports are specified in the port monitor's administrative file. The administrative file is configured by using the pmadm and ttyadm commands.
Console services are not managed by the Service Access Controller nor any explicit ttymon administration file. An entry in the /etc/inittab file is used to manage the console port by using ttymon in express mode. Express mode is a special ttymon mode that is invoked directly by a command that requires login service.
The default console entry in the /etc/inittab file is as follows:
| co:234:respawn:/usr/lib/saf/ttymon -g -h -p "`uname -n` console login: " -T terminal_type -d /dev/console -l console -m ldterm,ttcompat |
| co:234:respawn: | co identifies the entry as the console. 234 identifies the run levels for the action. respawn means the console entry should be restarted if it fails or doesn't exist at run levels 2, 3, and 4. |
| /usr/lib/saf/ttymon -g -h | The -g option is used so the correct baud rate and terminal setting can be set on a port and connect to a login service without being preconfigured by the SAC. The -h option forces a line hangup by setting the line speed to zero before setting the default or specified speed. |
| -p "`uname -n` console login: | Identifies the prompt string for the console port. |
| -t terminal_type | Identifies the terminal type of the console. |
| -d /dev/console -l console -m ldterm,ttcompat | The -d option identifies the console device. The -l option identifies the ttylabel in the /etc/ttydefs file. The -m option identifies the STREAMS modules to be pushed. |
The ttymon administrative file is updated by sacadm and pmadm, as well as by the ttyadm command. The ttyadm command formats ttymon-specific information and writes it to the standard output, providing a means for presenting formatted ttymon-specific data to the sacadm and pmadm commands.
Thus, ttyadm does not administer ttymon directly. The ttyadm command complements the generic administrative commands, sacadm and pmadm. For more information, see ttyadm(1M).
The listen port monitor runs under SAC and does the following:
Monitors the network for service requests
Accepts requests when they arrive
Invokes servers in response to those service requests
The listen port monitor is configured by using the sacadm command. Each instance of listen can provide multiple services. These services are specified in the port monitor's administrative file. This administrative file is configured by using the pmadm and nlsadmin commands.
The network listener process can be used with any connection-oriented transport provider that conforms to the Transport Layer Interface (TLI) specification. In the Solaris environment, listen port monitors can provide additional network services not provided by the inetd service.
The listen port monitor's administrative file is updated by sacadm and pmadm, as well as by the nlsadmin command. The nlsadmin command formats listen-specific information and writes it to standard output, providing a means of presenting formatted listen-specific data to the sacadm and pmadm commands.
Thus, nlsadmin does not administer listen directly. It complements the generic administrative commands, sacadm and pmadm.
Each network, configured separately, can have at least one instance of the network listener process associated with it. The nlsadmin command controls the operational states of listen port monitors.
The nlsadmin command can establish a listen port monitor for a given network, configure the specific attributes of that port monitor, and start and kill the monitor. The nlsadmin command can also report on the listen port monitors on a machine.
For more information, see nlsadmin(1M).
