This chapter provides step-by-step instructions for setting up terminals and modems using Solaris Management Console's Serial Ports Tool.
This is a list of the step-by-step instructions in this chapter.
For overview information about terminals and modems, see Chapter 10, Managing Terminals and Modems (Overview).
You can set up serial ports with the Solaris Management Console's Serial Ports Tool. Select a serial port from the Serial Ports window and then choose a Configure option from the Action menu to configure the following.
Terminal
Modem – Dial In
Modem – Dial Out
Modem – Dial In/Dial Out
Initialize Only – No Connection
The Configure options provide access to the templates for configuring the preceding services. You can view two levels of detail for each serial port: Basic and Advanced. You can access the Advanced level of detail for each serial port after it is configured by selecting the serial port and selecting the Properties option from the Action menu. After a serial port is configured, you can disable or enable the port with the SAF commands. For information on using the SAF commands, see Chapter 12, Managing Serial Ports With the Service Access Facility (Tasks).
For information on using the Serial Ports command line interface, see smserialport(1M).
The following table describes the menu items (and their default values) when setting up a terminal using Serial Ports.
Table 11–1 Terminal Default Values|
Detail |
Item |
Default Value |
Basic |
Port |
Description |
Terminal |
Service Status |
Enabled |
Baud Rate |
9600 |
Terminal Type |
tvi925 |
Login Prompt |
ttyn login: |
Advanced |
Carrier Detection |
Software |
Option: Connect on Carrier |
No |
Option: Bidirectional |
Yes |
Option: Initialize Only |
No |
Timeout (seconds) |
Never |
Port Monitor |
zsmon |
Service Program |
/usr/bin/login |
The following table describes the three modem templates available when setting up a modem using Serial Ports.
Table 11–2 Modem Templates|
Modem Configuration |
Description |
Dial-In Only |
Users can dial in to the modem but cannot dial out. |
Dial-Out Only |
Users can dial out from the modem but cannot dial in. |
Dial-In and Out (Bidirectional) |
Users can either dial in or out from the modem. |
The following table describes the default values of each template.
Table 11–3 Modem Template Default Values|
Detail |
Item |
Modem - Dial-In Only |
Modem - Dial-Out Only |
Modem - Dial In and Out |
Basic |
Port Name |
Description |
Modem – Dial In Only |
Modem – Dial Out Only |
Modem – Dial In and Out |
Service Status |
Enabled |
Enabled |
Enabled |
Baud Rate |
9600 |
9600 |
9600 |
Login Prompt |
ttyn login: |
ttyn login: |
ttyn login: |
Advanced |
Carrier Detection |
Software |
Software |
Software |
No |
No |
No |
No |
No |
Yes |
No |
Yes |
No |
Timeout (seconds) |
Never |
Never |
Never |
Port Monitor |
zsmon |
zsmon |
zsmon |
Service Program |
/usr/bin/login |
/usr/bin/login |
/usr/bin/login |
The following table describes the default values for the Initialize Only template.
Table 11–4 Initialize Only - No Connection Default Values|
Detail |
Item |
Default Value |
Basic |
Port Name |
Description |
Initialize Only - No Connection |
Service Status |
Enabled |
Baud Rate |
9600 |
Login Prompt |
ttyn login: |
Advanced |
Carrier Detection |
Software |
No |
Yes |
Yes |
Timeout (seconds) |
Never |
Port Monitor |
zsmon |
Service Program | /usr/bin/login |
Start the Solaris Management Console, if it's not already running.
% /usr/sadm/bin/smc & |
For information on starting the Solaris Management Console, see “Starting the Solaris Management Console” in System Administration Guide: Basic Administration.
Click This Computer icon in the Navigation pane.
Click Devices and Hardware—>Serial Ports.
The Serial Ports menu is displayed.
Select the port that will be used with a terminal.
Choose Configure—>Terminal from the Action menu.
The Configure Serial Port window appears in the Basic Detail mode.
For a description of the Terminal menu items, see Table 11–1.
Click OK.
To configure the advanced items, select the port configured as a terminal. Then, select Properties from the Action menu.
Change values of template entries if desired.
Click OK to configure the port.
Verify that the terminal service has been added.
$ pmadm -l -s ttyn |
Select the port that will be used with a modem.
Choose one of the following Configure options from the Action menu.
For a description of the Modem menu items, see Table 11–3.
Click OK.
To configure the advanced items, select the port configured as a modem. Then, select Properties from the Action menu.
Change the values of template entries if desired.
Verify that the modem service has been configured.
Select the port to be initialized.
Choose Configure—>Initialize Only – No Connection
The Serial Port window appears in the Basic Detail mode.
For a description of the Initialize Only menu items, see Table 11–4.
Click OK.
To configure the advanced items, select the port configured as a initialize only. Then, select Properties from the Action menu.
Verify that the modem service has been initialized.
If users are unable to log in over serial port lines after you have added a terminal or modem and set up the proper services, consider the following possible causes of failure.
Check with the user.
Malfunctions in terminals and modem use are typically reported by a user who has failed to log in or dial in. For this reason, it is best to begin troubleshooting by checking for a problem on the desktop.
Some common reasons for login failure include:
Login ID or password is incorrect.
Terminal is waiting for X-ON flow control key (Control-q).
Serial cable is loose or unplugged.
Terminal configuration is incorrect.
Terminal is shut off or otherwise has no power.
Check the terminal.
Continue to troubleshoot by checking the configuration of the terminal or modem. Determine the proper ttylabel for communicating with the terminal or modem. Verify that the terminal or modem settings match those of the ttylabel.
Check the terminal server.
If the terminal checks out, continue to search for the source of the problem on the terminal or modem server. Use the pmadm command to verify that a port monitor has been configured to service the terminal or modem and that it has the correct ttylabel associated with it.
$ pmadm -l -t ttymon |
Examine /etc/ttydefs and double check the label definition against the terminal configuration. Use sacadm to check the port monitor's status. Use pmadm to check the service associated with the port the terminal uses.
Check the serial connection.
If the Service Access Controller is starting the TTY port monitor and pmadm reports that the service for the terminal's port is enabled, and if the terminal's configuration matches the port monitor's, then continue to search for the problem by checking the serial connection. A serial connection comprises serial ports, cables, and terminals. Test each of these parts by using it with two other parts that are known to be reliable.
Test all of the following:
Serial ports
Modems
Cables
Connectors
Do not use Serial Ports Tool to modify serial port settings if the serial port is being used as a console. The correct procedure for changing console settings is by modifying the following line in the /etc/inittab file:
co:234:respawn:/usr/lib/saf/ttymon -g -h -p "`uname -n` console login: " -T terminal_type -d /dev/console -l console -m ldterm,ttcompat |
