Start the Solaris Management Console, if it's not already running.
% /usr/sadm/bin/smc & |
For information on starting the Solaris Management Console, see “Starting the Solaris Management Console” in System Administration Guide: Basic Administration.
Click This Computer icon in the Navigation pane.
Click Devices and Hardware—>Serial Ports.
The Serial Ports menu is displayed.
Select the port to be initialized.
Choose Configure—>Initialize Only – No Connection
The Serial Port window appears in the Basic Detail mode.
For a description of the Initialize Only menu items, see Table 11–4.
Click OK.
To configure the advanced items, select the port configured as a initialize only. Then, select Properties from the Action menu.
Change the values of template entries if desired.
Click OK to configure the port.
Verify that the modem service has been initialized.
$ pmadm -l -s ttyn |
