Start the Solaris Management Console, if it's not already running.
% /usr/sadm/bin/smc & |
For information on starting the Solaris Management Console, see “Starting the Solaris Management Console” in System Administration Guide: Basic Administration.
Click This Computer icon in the Navigation pane.
Click Devices and Hardware—>Serial Ports.
The Serial Ports menu is displayed.
Select the port that will be used with a terminal.
Choose Configure—>Terminal from the Action menu.
The Configure Serial Port window appears in the Basic Detail mode.
For a description of the Terminal menu items, see Table 11–1.
Click OK.
To configure the advanced items, select the port configured as a terminal. Then, select Properties from the Action menu.
Change values of template entries if desired.
Click OK to configure the port.
Verify that the terminal service has been added.
$ pmadm -l -s ttyn |
