This section provides instructions for day-to-day tasks you perform to manage printers and the print scheduler.
If a printer needs to be replaced or you want to move the printer to a different location, you must delete the printer information from the LP print service before you physically remove it from the print server. You should also make sure that all the current print requests on the printer are printed or moved to another printer to be printed.
Not only does the printer information need to be deleted from the print server, but it also needs to be deleted from the print clients or network name service. If you delete a local printer from a print server, you should delete the remote printer entry from the print clients or network name service. If you move a printer to another print server, you need to delete the old remote printer entry from the print clients or network name service. Then, add access to the remote printer in its new location.
For detailed information on how to delete a local and remote printer, see How to Delete a Printer and Remote Printer Access. You can use Solaris Print Manager to delete a local or remote printer. However, Solaris Print Manager does not enable you to move queued print requests to another printer.
Use this procedure when you remove a printer from service and you want to remove the printer access from the print clients. Then, remove the printer information from the print server.
Log in as superuser, lp, or assume an equivalent role on a print client that has access to the printer you want to delete.
Delete information about the printer from the print client.
print-client# lpadmin -x printer-name |
-x |
Deletes the specified printer. |
printer-name |
Name of the printer you want to delete. |
Information for the specified printer is deleted from the print client's /etc/lp/printers directory.
If the print client does not use another printer on the same print server, delete information about the print server from the print client.
print-client# lpsystem -r print-server |
-r |
Removes the specified print server. |
print-server |
Name of the print server you want to delete. |
The print server is deleted from the print client's /etc/lp/Systems file.
Repeat Step 2 through Step 3 on each print client that has access to the printer.
Log in as superuser or lp or assume an equivalent role on the print server.
Stop accepting print requests on the printer.
print-server# reject printer-name |
Rejects print requests for the specified printer. |
This step prevents any new requests from entering the printer's queue while you are in the process of removing the printer. For a detailed description, see How to Accept or Reject Print Requests for a Printer.
print-server# disable printer-name |
This step stops print requests from printing. For a detailed description on how to stop printing, see How to Enable or Disable a Printer.
Move any print requests that are still in the queue to another printer.
For a detailed description on how to move print requests to another printer, see How to Move Print Requests to Another Printer.
Delete the printer from the print server.
print-server# lpadmin -x printer-name |
Configuration information for the printer is deleted from the print server's /etc/lp/printers directory.
Delete information about the print clients that were using the printer you just deleted, unless they are still using another printer on the print server.
print-server# lpsystem -r print-client1[,print-client2 ...] |
-r |
Removes the specified print client. |
print-client |
Name of the print client you want to delete from the print server. You can specify multiple print clients in this command. Use a space or a comma to separate print client names. If you use spaces, enclose the list of print clients in quotes. |
The specified print clients are deleted from the print server's /etc/lp/Systems file.
Verify that the printer information has been deleted:
Confirm that the printer information has been deleted on the print client.
print-client$ lpstat -p printer-name -l |
You should receive an error indicating that the printer does not exist in the output of the preceding command.
Confirm that the printer information has been deleted on the print server.
print-server$ lpstat -p printer-name -l |
The following example shows how to delete the printer luna from the print client terra and from the print server jupiter. This example also shows how to delete the print client terra from the print server.
terra# lpadmin -x luna Removed “luna”. terra# lpstat -p luna -l jupiter# lpadmin -x luna jupiter# lpsystem -r terra Removed “terra”. jupiter# lpstat -p luna -l |
Many routine printer administration tasks require information about the status of the LP print service or a specific printer. For example, you can determine which printers are available for use and can examine the characteristics of those printers. You can use the lpstat command to find out status information about the LP print service or a specific printer.
Log in to any system on the network.
Check the status of printers.
Only the most commonly used options are shown here. For other options, see lpstat(1).
$ lpstat [-d] [-p printer-name [-D] [-l]] [-t] |
-d |
Shows the system's default printer. |
-p printer-name |
Shows if a printer is active or idle, when the printer was enabled or disabled, and whether the printer is accepting print requests. You can specify multiple printer names with this command. Use a space or a comma to separate printer names. If you use spaces, enclose the list of printer names in quotes. If you don't specify printer-name, the status of all printers is displayed. |
-D |
Shows the description of the specified printer-name. |
-l |
Shows the characteristics of the specified printer-name. |
-t |
Shows status information about the LP print service, including the status of all printers, such as whether they are active and whether they are accepting print requests. |
The following example shows how to displays the system's default printer.
$ lpstat -d system default destination: luna |
The following example shows how to display the status of the printer luna.
$ lpstat -p luna printer luna is idle. enabled since Jul 12 11:17 2001. available. |
The following example shows how to display the description of the printers asteroid and luna.
$ lpstat -p "asteroid luna" -D printer asteroid faulted. enabled since Jul 12 11:35 2001. available. unable to print: paper misfeed jam Description: Printer by break room printer luna is idle. enabled since Jul 12 11:36 2001. available. Description: Printer by server room. |
The following example shows how to display the characteristics of the printer luna.
$ lpstat -p luna -l printer luna is idle. enabled since Thu Jul 12 15:02:32 ... Form mounted: Content types: postscript Printer types: PS Description: Connection: direct Interface: /usr/lib/lp/model/standard After fault: continue Users allowed: (all) Forms allowed: (none) Banner not required Character sets: Default pitch: Default page size: 80 wide 66 long Default port settings: |
The print scheduler, lpsched, handles print requests on print servers. However, there might be times when the print scheduler stops running on a system, so print requests stop being accepted or printed.
The following section describes how to restart the print scheduler. If a print request was printing when the print scheduler stopped running, the print request will be printed in its entirety when you restart the print scheduler.
Log in as superuser, lp, or assume an equivalent role on the print server.
Check to see if the print scheduler is running.
# lpstat -r |
If the print scheduler is not running, the message scheduler is not running is displayed.
If the print scheduler is running, stop it.
# /etc/init.d/lp stop |
