Use this procedure when you remove a printer from service and you want to remove the printer access from the print clients. Then, remove the printer information from the print server.
Log in as superuser, lp, or assume an equivalent role on a print client that has access to the printer you want to delete.
Delete information about the printer from the print client.
print-client# lpadmin -x printer-name |
-x |
Deletes the specified printer. |
printer-name |
Name of the printer you want to delete. |
Information for the specified printer is deleted from the print client's /etc/lp/printers directory.
If the print client does not use another printer on the same print server, delete information about the print server from the print client.
print-client# lpsystem -r print-server |
-r |
Removes the specified print server. |
print-server |
Name of the print server you want to delete. |
The print server is deleted from the print client's /etc/lp/Systems file.
Repeat Step 2 through Step 3 on each print client that has access to the printer.
Log in as superuser or lp or assume an equivalent role on the print server.
Stop accepting print requests on the printer.
print-server# reject printer-name |
Rejects print requests for the specified printer. |
This step prevents any new requests from entering the printer's queue while you are in the process of removing the printer. For a detailed description, see How to Accept or Reject Print Requests for a Printer.
print-server# disable printer-name |
This step stops print requests from printing. For a detailed description on how to stop printing, see How to Enable or Disable a Printer.
Move any print requests that are still in the queue to another printer.
For a detailed description on how to move print requests to another printer, see How to Move Print Requests to Another Printer.
Delete the printer from the print server.
print-server# lpadmin -x printer-name |
Configuration information for the printer is deleted from the print server's /etc/lp/printers directory.
Delete information about the print clients that were using the printer you just deleted, unless they are still using another printer on the print server.
print-server# lpsystem -r print-client1[,print-client2 ...] |
-r |
Removes the specified print client. |
print-client |
Name of the print client you want to delete from the print server. You can specify multiple print clients in this command. Use a space or a comma to separate print client names. If you use spaces, enclose the list of print clients in quotes. |
The specified print clients are deleted from the print server's /etc/lp/Systems file.
Verify that the printer information has been deleted:
Confirm that the printer information has been deleted on the print client.
print-client$ lpstat -p printer-name -l |
You should receive an error indicating that the printer does not exist in the output of the preceding command.
Confirm that the printer information has been deleted on the print server.
print-server$ lpstat -p printer-name -l |
The following example shows how to delete the printer luna from the print client terra and from the print server jupiter. This example also shows how to delete the print client terra from the print server.
terra# lpadmin -x luna Removed “luna”. terra# lpstat -p luna -l jupiter# lpadmin -x luna jupiter# lpsystem -r terra Removed “terra”. jupiter# lpstat -p luna -l |
