Log in as superuser, lp, or assume an equivalent role on the print server.
Set up fault recovery for the printer.
# lpadmin -p printer-name -F recovery-options |
-p printer-name |
Name of the printer for which you are specifying fault recovery. |
One of the three valid recovery options: beginning, continue, or wait. For detailed information about the valid values for recovery-options, see Table 5–4. |
For more information, see lpadmin(1M).
The fault recovery setting is entered in the print server's /etc/lp/printers/printer-name/configuration file.
Check the information following the After fault heading in the output of the following command.
$ lpstat -p printer-name -l |
The following example shows how to set up the printer luna to continue printing at the top of the page where printing stopped.
# lpadmin -p luna -F continue |
