Log in as superuser, lp, or assume an equivalent role on the print server.
Allow or deny users access to a printer.
| # lpadmin -p printer-name -u allow:user-list [ deny:user-list] |
| -p printer-name | Name of the printer to which the allow or deny user access list applies. |
| -u allow:user-list | User names to be added to the allow user access list. You can specify multiple user names with this command. Use a space or a comma to separate names. If you use spaces, enclose the list of names in quotes. Table 5–5 provides the valid values for user-list. |
| -u deny:user-list | User names to be added to the deny user access list. You can specify multiple user names with this command. Use a space or a comma to separate names. If you use spaces, enclose the list of names in quotes. Table 5–5 provides the valid values for user-list. |
The specified users are added to the allow or deny list for the printer in one of the following files on the print server:
/etc/lp/printers/printer-name/users.allow
/etc/lp/printers/printer-name/users.deny
If you specify none as the value for user-list in the allow list, the following files are not created for the print server:
/etc/lp/printers/printer-name/alert.sh
/etc/lp/printers/printer-name/alert.var
Check the information following the Users allowed or Users denied heading in the output of the following command.
| $ lpstat -p printer-name -l |
The following example shows how to allow only nathan and george access to the printer luna.
| # lpadmin -p luna -u allow:nathan,george |
The following example shows how to deny nathan and george access to the printer asteroid.
| # lpadmin -p asteroid -u deny:"nathan george" |
