The lpadmin command has a new -n option. This option enables you to specify the PPD file that you want to use to create a new print queue or modify an existing print queue.
For example, if you wanted to add the queue, foobar, to a Lexmark printer, you would type the following command:
# lpadmin -p foobar -v device -I postscript -m standard_foomatic \ -n /usr/lib/lp/model/ppd/Lexmark/Lexmark-Optra_E312-Postscript.ppd.gz |
When using the -n option to the lpadmin command, specify the full path and file name to the PPD file, as shown in the previous example.
For more information, see the lpadmin(1M) man page.
