System Administration Guide: Advanced Administration
How to Adjust the Printer Port Characteristics
  1. Log in as superuser, lp, or assume an equivalent role on the print server.
  2. Adjust the printer port characteristics.
    # lpadmin -p printer-name -o "stty=options"
    -p printer-name
    Name of the printer for which you are adjusting the port characteristics.
    -o "stty=options”
    Sets the port characteristic (stty option) specified by options. You can change more than one stty option setting with this command. Enclose each option in single quotation marks and use a space to separate the options. For a complete list of options, see stty(1). Table 7–1 shows the default stty settings used by the LP print service.
  3. Verify that the printer port characteristics have been changed.
    # lpstat -p printer-name -l
Examples—Adjusting the Printer Port Characteristics
The following example shows how to set the port characteristics for the printer luna. The parenb option enables parity checking/generation, parodd sets odd parity generation, and cs7 sets the character size to 7 bits.
# lpadmin -p luna -o "stty='parenb parodd cs7'"
The following example shows how to set the terminal baud rate to 19200 for the printer venus.
# lpadmin -p venus -o "stty=19200"
