Log in as superuser, lp, or assume an equivalent role on the print server.
Unmount the print wheel or font cartridge that is in the printer.
# lpadmin -p printer-name -M -S none |
-p printer-name |
Printer on which you are unmounting a print wheel or font cartridge. |
-M -S none |
Specifies unmounting the current print wheel or font cartridge. |
For more information, see lpadmin(1M).
The current print wheel or font cartridge is deleted from the print server's /etc/lp/printers/printer-name/configuration file.
Remove the print wheel or font cartridge from the printer.
Put the new print wheel or font cartridge in the printer.
Mount the new print wheel or font cartridge.
# lpadmin -p printer-name -M -S hard-charset |
-p printer-name |
Printer on which you are mounting a print wheel or font cartridge. |
Hardware character set name of the print wheel or font cartridge you want to mount. |
The print wheel or font cartridge is added in the print server's /etc/lp/printers/printer-name/configuration file. The mounted print wheel or font cartridge remains active until it is unmounted or until a new print wheel or font cartridge is mounted.
Check that the information under the Print wheels or Character set heading in the output of the following command. You should see the name of the print wheel or character set and the notation (mounted)
$ lpstat -p printer-name -l |
The following example shows how to unmount the current print wheel on the printer luna and mount the pica print wheel.
# lpadmin -p luna -M -S none # lpadmin -p luna -M -S pica |
