Log in as superuser, lp, or assume an equivalent role on the print server.
Add a print filter that is based on a print filter definition.
# lpfilter -f filter-name -F filter-def |
-f filter-name |
Name you choose for the print filter. |
-F filter-def |
Name of the print filter definition. |
For more information, see lpfilter(1M).
The print filter is added in the print server's /etc/lp/filter.table file.
Verify that the print filter was added by checking for information about the print filter in the output of the following command.
# lpfilter -f filter-name -l |
The following example shows how to add the daisytroff print filter that has the daisytroff.fd print filter definition.
# lpfilter -f daisytroff -F /etc/lp/fd/daisytroff.fd |
