This chapter provides background information on the LP print service.
Printer Task |
For More Information |
Set up printers with Solaris Print Manager and the lp commands | |
Administer printers with the lp commands after the printers are setup | |
Manage character sets, filters, forms, and fonts |
Chapter 6, Managing Character Sets, Filters, Forms, and Fonts (Tasks) |
Customize the LP print service |
The LP print service is a set of software utilities that allows users to print files while users continue to work. Originally, the print service was called the LP spooler. (LP stood for line printer, but its meaning now includes many other types of printers, such as laser printers. Spool is an acronym for system peripheral operation off-line.)
The print service consists of the LP print service software, any print filters you might provide, and the hardware, such as the printer, system, and network connections.
This section describes the directory structure, files, logs, and commands of the LP print service.
The files of the LP print service are distributed among seven directories, as shown in the following table.
Table 8–1 Directories for the LP Print Service|
Directory |
Contents |
/usr/bin |
The LP print service user commands |
/etc/lp |
A hierarchy of LP server configuration files |
/usr/share/lib |
The terminfo database directory |
/usr/lib/print |
The lp conversion scripts, in.lpd daemon and the printd daemon. The printd daemon transfers all pending jobs in the/var/spool/print directory once per minute. When no jobs are remaining to transfer, it exits. |
/usr/sbin |
The LP print service administrative commands |
/usr/lib/lp |
The lpsched program, binary files, PostScript filters, and the model directory, which contains the standard printer interface program. |
/var/lp/logs |
LP log files such as lpsched.n, which includes messages from lpsched and requests.n, which includes information about completed print requests. |
/var/spool/lp |
The spooling directory where files are queued for printing |
/var/spool/print |
The LP print service client-side request staging area |
The lpsched daemon stores configuration information in the /etc/lp directory, as described in the following table.
The configuration files listed in this table are private interfaces, and are subject to change in future releases. You should not build software that relies on these files being in their current locations or that relies on the data being in the format currently used.
File |
Type |
Description |
classes |
Directory |
Files identifying classes provided by the lpadmin -c command. |
fd |
Directory |
Description of existing filters. |
filter.table |
File |
Print filter lookup table. |
forms |
Directory |
Location to put files for each form. Initially, this directory is empty. |
interfaces |
Directory |
Printer interface program files. |
logs |
Link to /var/lp/logs |
Log files of printing activities. |
model |
Link to /usr/lib/lp/model |
The standard printer interface program. |
printers |
Directory |
Directories for each local printer. Each directory contains configuration information and alert files for an individual printer. |
pwheels |
Directory |
Print wheel or cartridge files. |
These configuration files serve a similar function to the /etc/printcap file on lpd-based print servers.
You can check the contents of the configuration files, but you should not edit these files directly. Instead, use the lpadmin command to make configuration changes. Your changes will be written to the configuration files in the /etc/lp directory. The lpsched daemon administers and updates the configuration files.
The /etc/lp/printers directory has a subdirectory for each local printer known to the system. The following example shows the /etc/lp/printers subdirectories of printers sparc1 and luna.
$ ls -l /etc/lp/printers drwxrwxr-x 2 lp lp 512 Jan 23 23:53 luna drwxrwxr-x 2 lp lp 512 Jan 11 17:50 sparc1 |
The following table describes the files within each of the printer-specific directories.
File Name |
Description |
alert.sh |
Shell to execute in response to alerts |
alert.vars |
Alert variables |
configuration |
Configuration file |
users.deny |
List of users to whom printer access is denied |
comment |
Printer description |
The configuration file for the printer luna, /etc/lp/printers/luna/configuration, would typically appear as follows:
Banner: on: Always Content types: PS Device: /dev/term/b Interface: /usr/lib/lp/model/standard Printer type: PS Modules: default |
The /usr/share/lib directory contains the terminfo database directory, which contains definitions for many types of terminals and printers. The LP print service uses information in the terminfo database to initialize a printer, to establish a selected page size, character pitch, line pitch, and character set, as well as to communicate the sequence of codes to a printer.
Each printer is identified in the terminfo database with a short name. For a description of the structure of the terminfo database, see Printer Type. If necessary, you can add entries to the terminfo database, but doing so is a tedious and time-consuming process. For more information, see Adding a terminfo Entry for an Unsupported Printer.
The /usr/lib/lp directory contains daemons and files used by the LP print service, as described in the following table.
Table 8–3 Contents of the /usr/lib/lp Directory|
File |
Type |
Description |
bin |
Directory |
Contains files for generating printing alerts, slow filters, and queue management programs. |
lpsched |
Daemon |
Manages scheduling of LP print requests. |
model |
Directory |
Contains the standard printer interface program. |
postscript |
Directory |
Contains all PostScript filter programs provided by the LP print service. These filters come with descriptor files in the /etc/lp/fd directory that tell the LP print service the characteristics of the filters and where to locate them. |
The LP print service maintains two sets of log files that are described in the following table.
Log File Name |
Description |
Set lpr.debug in /etc/syslog.conf to enable LP print service logging |
/var/spool/lp |
A list of current requests that are in the print queue |
/var/lp/logs/requests |
An ongoing history of print requests |
The scheduler for each system keeps a log of print requests in the /var/spool/lp/tmp/system and /var/spool/lp/requests/system directories. Each print request has two files, one in each directory, that contain information about the request. The information in the /var/spool/lp/requests/system directory can be accessed only by root or lp. The information in the /var/spool/lp/tmp/system directory can be accessed only by the user who submitted the request, root, or lp.
The following example shows the contents of the /var/spool/lp/tmp/starbug directory:
$ ls /var/spool/lp/tmp/starbug 5 5-0 # cat 5-0 C 1 D print1 F /etc/profile P 20 T /etc/profile t simple U root s 0000 v 2 |
These files remain in their directories only as long as the print request is in the queue. Once the request is finished, the information in the files is combined and appended to the /var/lp/logs/requests file. This file is described in the next section.
Use the information in the /var/spool/lp/logs directory if you need to track the status of a print request that is currently in the queue.
The LP print service records a history of printing services in two log files, lpsched and requests. These log files are located in the /var/lp/logs directory. You can use the information in these logs to diagnose and troubleshoot printing problems. An example of the contents of the /var/lp/logs directory is as follows:
# cd /var/lp/logs # ls lpsched.1 requests requests.2 lpsched lpsched.2 requests.1 # |
The two most important log files for troubleshooting is the lpsched log, which contains information about local printing requests and the requests log, which contains information about print requests that are completed and no longer in the print queue.
The requests log has a simple structure, so that you can extract data using common UNIX shell commands. Requests are listed in the order they are printed, and are separated by lines showing their request IDs. Each line below the separator line, the line that starts with =, is marked with a single letter that identifies the kind of information contained in that line. Each letter is separated from the data by a single space.
The following example shows the contents of a requests log:
# pwd /var/lp/logs # tail requests.2 = print1-3, uid 0, gid 1, size 206662, Wed Mar 14 08:56:30 MST 2003 z print1 C 1 D print1 F /usr/dict/words P 20 T /usr/dict/words t simple U root s 0x0014 v 2 # |
The following table shows the letter codes and the content of their corresponding lines in the LP requests log.
Table 8–4 Letter Codes in the LP requests Log|
Letter |
Content of Line |
The separator line, which contains the following items: request ID, user ID (UID), and group IDs (GIDs) of the user, the total number of bytes in the original (unfiltered) file size, and the time when the request was queued. |
z |
The name of the printer. |
C |
The number of copies printed. |
D |
The printer or class destination or the word any. |
F |
The name of the file printed. The line is repeated for each file printed. Files were printed in the order shown. |
f |
(Optional) The name of the form used. |
H |
(Optional) One of three types of special handling: resume, hold, and immediate. |
N |
(Optional) The type of alert used when the print request was successfully completed. The type is the letter M if the user was notified by email or W if the user was notified by a message to the terminal. |
O |
(Optional) The printer-dependent -o options. For example, nobanner. |
P |
The priority of the print request. |
p |
The list of pages printed. |
r |
(Optional) A single-letter line that is included if the user asked for “raw” processing of the files with the lp -r command. |
S |
(Optional) The character set, print wheel, or cartridge used. |
T |
The title placed on the banner page. |
t |
The type of content found in the files. |
U |
The name of the user who submitted the print request. |
s |
The outcome of the request, shown as a combination of individual bits expressed in hexadecimal form. Several bits are used internally by the print service. The bits and what they mean are described in the table that follows this table. |
x |
(Optional) The slow filter used for the print request. |
Y |
(Optional) The list of special modes for the print filters used to print the request. |
z |
(Optional) The printer used for the request. This printer differs from the destination (the D line) if the request was queued for any printer or a class of printers, or if the request was moved to another destination. |
The following table shows the outcome codes in the LP requests log and their descriptions.
Table 8–5 Outcome Codes in the LP requests Log|
Outcome Code |
Description |
0x0001 |
The request was held pending resume. |
0x0002 |
Slow filtering is running. |
0x0004 |
Slow filtering finished successfully. |
0x0008 |
The request is on the printer. |
0x0010 |
Printing finished successfully. |
0x0020 |
The request was held pending user change. |
0x0040 |
The request was canceled. |
0x0080 |
The request will print next. |
0x0100 |
The request failed filtering or printing. |
0x0200 |
The request is in transit to a remote printer. (obsolete) |
0x0400 |
The user will be notified. |
0x0800 |
A notification is running. |
0x1000 |
A remote system has accepted the request. (obsolete) |
0x2000 |
The administrator placed a hold on the request. |
0x4000 |
The printer had to change filters. |
0x8000 |
The request is temporarily stopped. |
Files queued for printing are stored in the /var/spool/lp directory until they are printed, which might be only seconds. The following table shows the contents of the /var/spool/lp directory.
Table 8–6 Contents of the /var/spool/lp Directory|
File |
Type |
Description |
SCHEDLOCK |
File |
Lock file for the scheduler. Check for this file if the scheduler terminates and will not restart. |
admins |
Directory |
Link to /etc/lp. |
bin |
Directory |
Link to /usr/lib/lp/bin. |
logs |
Link |
Link to ../lp/logs where completed print requests are logged. |
model |
Link |
Link to /usr/lib/lp/model. |
requests |
Directory |
Directory that contains subdirectories for each configured printer where print requests are logged until printed. Users cannot access this log. |
system |
Directory |
A print status file for the system. |
temp |
Link |
Link to /var/spool/lp/tmp/hostname, which contains the spooled requests. |
tmp |
Directory |
Directory for each configured printer where print requests are logged until printed. Changes to existing print requests are also recorded in this log. |
The following table lists frequently used LP print service commands. You must be root, lp, or assume an equivalent role to use the 1M commands.
Table 8–7 Quick Reference to LP Print Service Commands|
Command |
Man Page |
Task |
enable |
Activate a printer |
cancel |
Cancel a print request |
lp |
Send one or more file(s) to a printer |
lpstat |
Report the status of the LP print service |
disable |
Deactivate one or more printers |
accept |
Permit print requests to be queued for a specific destination |
reject |
Prevent print requests from being queued for a specific destination |
lpadmin |
Set up or change printer configuration |
lpfilter |
Set up or change filter definitions |
lpforms |
Set up or change preprinted forms |
lpadmin |
Mount a form |
lpmove |
Move output requests from one destination to another destination |
lpsched |
Start the LP print service scheduler |
lpshut |
Stop the LP print service scheduler |
lpusers |
Set or change the default priority and priority limits that can be requested by users of the LP print service |
The LP print service performs the following functions:
Administers files and schedules local print requests
Receives and schedules network requests
Filters files, if necessary, so they print properly
Starts programs that interface with the printers
Tracks the status of jobs
Tracks forms mounted on the printer
Tracks print wheels currently mounted
Delivers alerts to mount new forms or different print wheels
Delivers alerts about printing problems
The LP print service has a scheduler daemon called lpsched. The scheduler daemon updates the LP system files with information about printer setup and configuration.
The lpsched daemon schedules all local print requests on a print server, as shown in the following figure, whether users issue the requests from an application or from the command line. Also, the scheduler tracks the status of printers and filters on the print server. When a printer finishes a request, the scheduler schedules the next request, if one exists, in the queue on the print server.
Each print server must have only one LP scheduler running. The scheduler is started when a system is booted, or enters run level 2, by the /etc/rc2.d/S80lp control script. Without rebooting the systems, you can stop the scheduler with the /etc/init.d/lp stop command and restart the scheduler with the /etc/init.d/lp start command. The scheduler for each system manages requests issued to the system by the lp commands.
Each print client communicates directly with a print sever over the network. The communication is done between the requesting command, such as lp, lpstat, cancel, lpr, lpq, or lprm, and the print service on the print server. Doing so, reduces the print system overhead on client only systems, improving scalability, performance and accuracy of data.
Print servers listen for print request with the Internet services daemon (inetd). Upon hearing a request for print service from the network, the inetd daemon starts a program called the “protocol adaptor” (in.lpd). The protocol adaptor translates the print request and communicates it to the print spooler, and returns the results to the requester. This protocol adaptor starts on demand and exits when it has serviced the network request. This process eliminates idle system overhead for printing. This process also eliminates any additional system configuration for network printing support as was the case in previous versions of Solaris printing.
Print filters are programs on the print server that convert the content of a queued file from one format to another format.
A print filter can be as simple or as complex as needed. The SunOS release provides print filters in the /usr/lib/lp/postscript directory that cover most situations where the destination printer requires the data to be in PostScript format. If you need filters for non-PostScript printers, you have to create the filters and add them to the systems that need filters.
A set of print filter descriptor files are provided in the /etc/lp/fd directory. These descriptor files describe the characteristics of the filter (for example, fast or slow filter), and point to the filter program (for example, /usr/lib/lp/postscript/postdaisy).
The LP print service interacts with other parts of the operating system. The print service uses a standard printer interface program to do the following:
Initialize the printer port, if necessary. The standard printer interface program uses the stty command to initialize the printer port.
Initialize the printer. The standard printer interface program uses the terminfo database and the TERM shell variable to find the appropriate control sequences.
Print a banner page, if necessary.
Print the correct number of copies specified by the print request.
The LP print service uses the standard interface program, found in the /usr/lib/lp/model directory, unless you specify a different program. You can create custom interface programs, but you must make sure that the custom program does not terminate the connection to the printer or interfere with proper printer initialization.
The lpsched daemon keeps a log of each print request that it processes and notes any errors that occur during the printing process. This log is kept in the /var/lp/logs/lpsched file. Every night, the lp cron job renames the /var/lp/logs/lpsched file to a new lpsched.n file and starts a new log file. If errors occur or jobs disappear from the print queue, you can use the log files to determine what the lpsched daemon has done with a printing job.
The lpsched and requests log files in the /var/lp/logs directory grow as information is appended. The LP print service uses a default cron job to clean out the log files. The lp cron job is located in the /var/spool/cron/crontabs/lp file. The cron job periodically moves the contents of the log files. The contents of log are moved to log.1, and the contents of log.1 are moved to log.2. The contents of log.2 are lost (that is, replaced by the former contents of log.1) when log.2 gets overwritten.
The requests log file on the printer server is rotated weekly rather than daily. You can change the rotation interval back to daily if the printer server is busy.
Become superuser or lp on the printer server.
Set the EDITOR environment variable.
# EDITOR=vi # export EDITOR |
Edit the lp crontab file.
# crontab -e lp |
Change the first line of the file which rotates the requests log files every Sunday (0) to an asterisk (*) for daily rotation:
13 3 * * * cd /var/lp/logs; if [ -f requests ]; then if [ -f requests.1 ]; then /bin/mv requests.1 requests.2; fi; /usr/bin/cp requests requests.1; >requests; fi |
Save the file and exit.
The print request follows the same path it would if the client and server were separate systems. Requests always flow from client to server following the same path.
The following figure shows what happens when a user submits a request to print a PostScript file on a local printer, which is a printer connected to the user's system. The lpsched daemon on the local system does all processing, which might include matching the printer and content type, identifying the default printer, filtering the request, and starting the specified printer interface program.
The printer interface program does the following:
Prints the banner page.
Catches printer faults.
Determines the printer fault policy to either reset, continue, or begin the print job over again.
Finally, the interface program uses the lpcat program to download the print request to the local printer's serial port.
The following figure shows what happens when a user on a Solaris print client submits a print request to an lpd-based print server. The command opens a connection and handles it's own communications with the print server directly.
The following figure shows a lpd-based print client submitting a print request to a Solaris print server. The lpd daemon handles the local part of the print request and the connection to the print server. On the print server, the inetd process waits for network printing requests and starts a protocol adaptor to service the request. The protocol adaptor communicates with the lpsched daemon, which processes the request on the print server.
The following figure shows what happens when a user on a Solaris print client submits a print request to a Solaris print server. The print command on the print client handles the local part of each print request by communicating directly with the print server.
The inetd process on the print server monitors network printing requests and starts a protocol adaptor to communicate with the lpsched daemon on the print server, which processes the print request.
