System Administration Guide: Advanced Administration
Setting Up Printing (Task Map)
Task
Description
For Instructions
Add a new attached printer by using Solaris Print Manager.
Use Solaris Print Manager to make the printer available for printing after you physically attach the printer to a system.
How to Add a New Attached Printer by Using Solaris Print Manager
Add a new attached printer by using LP print service commands.
Use LP print service commands to make the printer available for printing after you physically attach the printer to a system.
How to Add a New Attached Printer by Using LP Print Service Commands
Add access to a printer.
Use Solaris Print Manager to add printer access on the print client.
How to Add Printer Access by Using Solaris Print Manager
(Optional) Set up a .printers file.
Use a $HOME/.printers file so that users can establish their own custom printer aliases.
How to Set Up a .printers File
Add a new network printer by using vendor-supplied tools.
Use Printer Vendor Supplied Tools to configure the network printer after you physically connect the printer to the network.
After you physically connect the printer to the network, configure the network printer by using LP print service commands.
How to Add a New Network Printer With Printer Vendor-Supplied Tools
How to Add a New Network Printer by Using LP Print Service Commands
Add a new network printer by using Solaris Print Manager.
Use Solaris Print Manager to make a printer available for printing over the network.
How to Add a New Network Printer by Using Solaris Print Manager
Add a new network printer by using LP print service commands.
Use LP print service commands to make a printer availabe for printing over the network.
(Optional) Turn off banner pages.
You can turn off banner pages so that the banner pages are never printed.
How to Turn Off Banner Pages
(Optional) Set up fault alerts.
You can set up more specific fault alerts for the printer than the fault alerts provided by Solaris Print Manager.
How to Set Fault Alerts for a Printer
(Optional) Set up fault recovery.
You can set up how a printer should recover after it faults.
How to Set Printer Fault Recovery
(Optional) Limit access to a printer.
Solaris Print Manager enables you to set up an allow list. If you want to limit the access of a few users to the printer, you might want to set up a deny list.
How to Limit User Access to a Printer
Setting Up Printing by Using Solaris Print Manager
Solaris Print Manager is a Java-based graphical user interface that enables you to manage local and remote printer configuration. This tool can be used in the following name service environments: LDAP, NIS, NIS+, NIS+ with Federated Naming Service (xfn), and files. You must be logged in as superuser to use this tool.
You can use Solaris Print Manager to set up print servers (Add New Attached Printer or Add a Network Printer) and print clients (Add Access to Printer). A local or attached printer is a printer which is physically cabled to the print server. A network printer is physically attached to the network. You can use Solaris Print Manager to add a local printer or a network printer. Adding access to a printer, or adding remote access, is the process of giving print clients (all those machines which are not the server) access to the printer.
Printer Setup With Solaris Print Manager
The following table describes each printer attribute to help you determine the information that is needed to set up a printer with Solaris Print Manager.
Printer Definition
Description
Example
Default Setting
Required or Optional?
Printer Name
Name of printer
laser1
N/A
Required to install an attached or network printer and to add access to a printer
Printer server
Name of print server
venus
N/A
Required to install an attached or network printer and to add access to a printer — This field is filled in by the tool
Description
User defined string
laser printer near breakroom
N/A
Optional
Printer Port
Device that the printer is attached to
/dev/term/a
/dev/term/a
Required to install an attached printer
Printer Type
Type of printer
unknown
PostScript
Required to install an attached printer or a network printer for releases prior to Solaris 9 9/04
File Content Type
Content to be printed
any
PostScript
Printer Make
Make of printer
Lexmark
N/A
Printer Model
Model of printer
Lexmark Optra E312
N/A
Printer Driver
Driver that is used by specifying PPD file
Foomatic/PostScript
N/A
Destination
Destination name for the network printer
For examples, see Selecting the Destination (or Network Printer Access) Name
N/A
Required to install a network printer
Protocol
Protocol used to communicate with the printer
TCP
BSD
Fault Notification
Specifies how to notify user of errors
Mail to superuser
Write to superuser
Optional
Default Printer
Identifies the default printer
N/A
N/A
Optional
Always Print Banner
Print banner with print job?
N/A
Banner is printed
Optional
User Access List
List of users allowed to print on the print server
rimmer,lister
All users can print
Optional
Solaris Print Manager and Special Characters
Solaris Print Manager checks user input for the various text fields in the input screens. There are two types of checking: general illegal input and input that is illegal for specific fields.
Solaris Print Manager does not accept the following characters as input, except for the help screens:
