This example shows how to add a new attached printer without PPD files. The commands in this example must be executed on the print server where the printer is connected. The following information is used as an example. The information that you provide will vary:
Printer name: luna
Port device: /dev/term/b
Printer type: PS
File content type: postscript
# chown lp /dev/term/b # chmod 600 /dev/term/b 1 # lpadmin -p luna -v /dev/term/b 2 # lpadmin -p luna -T PS 3 # lpadmin -p luna -I postscript 4 # lpadmin -p luna -D "Room 1954 ps" 5 # cd /etc/lp/fd # for filter in *.fd;do > name=`basename $filter .fd` > lpfilter -f $name -F $filter > done 56 # accept luna destination “luna” now accepting requests # enable luna 7 printer “luna” now enabled # lpstat -p luna 8 printer luna is idle. enabled since Feb 28 11:21 2003. available. |
Gives lp ownership and sole access to a port device
Defines the printer name and the port device that the printer will use
Sets the printer type of the printer
Specifies the file content types to which the printer can print directly
Adds a description for the printer
Adds print filters to the print server
Accepts print requests for the printer and enables the printer
Verifies that the printer is ready
