System Administration Guide: Advanced Administration
How to Set Up a .printers File
  1. Log in to the user's system as superuser.
  2. Start the file editor that you want to use to create a .printers file in the user's home directory.
  3. (Optional) Set up the _default alias to make a specific printer your default printer. Use an entry that is similar to the entry shown in the following example.
    _default printer-name
  4. (Optional) Set up the _all alias to define the printers affected when you cancel a print request or check the status of printers, using an entry similar to the one shown in the next example.
    _all printer1,printer2,printer3
  5. Save the file as .printers.
